which cam?
Old May 20, 2006 | 07:54 PM
jjames455's Avatar
Car: 88 Formula, 77 T/A, 96 Z28
Engine: LO3, W72, LT1
Transmission: 700R4, 350, 4L60E
Axle/Gears: 3.42, 3.23, 3.23
which cam?
hello every one. i have an 88 formula with a 91 LO3 in it. previous owner ditched the tbi for a performer and 600 vacuum sec holley. this car is just a low buget project for me. i have aquired to factory cams and 89 L98 and a 93 Lt1. my engine currently has the stock "peanut" cam in it. I running 1.6 roller rockers. engine has stock heads will either of these cams work with these heads and 1.6 rockers without machine work? i want to use the LT1 but I understand with 1.6 rocker the lift is around 480. the L98 is #049 and i believe has a degree or two more duration(207/213,"413/"430) than the Lt1 but has 117 lobe separation. money is tight and aftermarket cam is not possible at this time.
which cam can i use and with the performer/holley/flowtech headers/"3 pipe/flowmaster dual outlet/1Le a/c delete/ underdrive pulleys/no air pump what kind of power can i expect?
Old May 25, 2006 | 12:53 AM
jjames455's Avatar
anyone?
Old May 25, 2006 | 01:20 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Plan on putting on new springs with either one and 1.6:1 rockers.
More lift and slightly less duration means more torque. I'd go with the LT1 after you verify the valves can handle the lift.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
