engine stumbles
Old May 20, 2006 | 10:37 PM
xaivior's Avatar
Car: Camaro
Engine: 355
Transmission: th-350
Axle/Gears: 3.73 welded
engine stumbles
ok i can't think of anymore things so maybe you guys can help..
when i hit the carb linkage on the engine it dont REV it revs up maybe 1-200 rpm
and then stops like it goes back to idle but if i hold the linkage back mabye 2-3 seconds after the pause it revs up ....... i want it to hit man!!!!!!!!
Old May 20, 2006 | 11:49 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Sounds like your accelerator pump is shot.
Old May 21, 2006 | 11:00 AM
xaivior's Avatar
Car: Camaro
Engine: 355
checked them both out ...both work fine...
any other ideas?? as of now im stumped on this one
Old May 21, 2006 | 11:04 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
Timing retarded?
Old May 21, 2006 | 11:08 AM
xaivior's Avatar
Car: Camaro
Engine: 355
i set the timing to 8* btdc
Old May 22, 2006 | 06:55 PM
AmandasBird's Avatar
Car: 86 Pontiac Firebird
Engine: 305 carb
Axle/Gears: stock
I THINK WE NEED A REBUILD!!!
Old May 22, 2006 | 07:11 PM
xaivior's Avatar
Car: Camaro
Engine: 355
I know you need a rebuild.... but we start on that after we build mine!!! muhahaha
Old May 22, 2006 | 07:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Lunati cam .480 lift 292 degrees duration
i'm not sure how you're getting that beast to stay running with a cam like that, and only 8*. Your throttle plates must be pretty far open. Bump up to 20* timing, stay on ported vacuum for now. See if that helps.
If not, keep your idle speed ~800RPM. flick the throttle, only revs up 200RPM more? but you can see accelerator pump shooting fuel? cup your hands over the air intake of the carb, does idle change? you're making it rich, so if idle gets nicer, you need to jet it to be richer at idle, if idle gets way worse, it's too rich, lean it out at idle. If you flick the throttle, and get a puff of black, it's also too rich. Check your plugs to verify that too.
Old May 28, 2006 | 07:22 AM
xaivior's Avatar
Car: Camaro
Engine: 355
sorry it took so long to get back ... ill have to go through it tommorow .. right now we think it has a broken ring or blown head gasket ...you know what that means ..when its rebuilt gotta build it bigger and meaner than before
theshackle
Sep 17, 2020 08:26 AM
mdtoren
Aug 23, 2015 12:52 PM
Winchester1094
Aug 18, 2015 10:23 AM
wayshegoes
Aug 17, 2015 12:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
