L03 problems
Old May 22, 2006 | 11:44 PM
25th rs camaro's Avatar
Car: 1992 Camaro Rally Sport
Engine: L03 305 E TBI
Transmission: M5
Axle/Gears: 3.08
L03 problems
Ok i have a 92 L03 with 150xxx miles on it and when i press the gas it doesnt want to accelerate like it should. It has no power at all not even the power of a 4 cylinder more like 2 cylinders i have put a plethora of new parts on it but at this point i am just stuck at what this new problem could be caused by It kinda sounds like its not geting enough fuel. I checked the injectors they have the right voltage and the ECM and all the sensors are brand new so its probably not elecronicly related. But the thing that stumps me is the car is still drinking up gas, maybe its lack of spark? Idk. Any suggestions would be appriciated.
Old May 23, 2006 | 12:29 AM
Transmission: M5
Axle/Gears: 3.08
Does this sound like a fuel pump issue? Im really hoping its not because im not looking forward to removing the gas tank.
Old May 23, 2006 | 05:39 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Did you change your fuel filter? And does it rev up like this in park or N?
Old May 23, 2006 | 11:13 AM
Damon's Avatar
Check your base ignition timing using the correct factory procedure. Also, the timing tab on these motors is not easy to find if you've never gone looking for it before- look straight down behind the water pump.
Retarded timing will definitely make the motor run badly and most people do not know the right way to set base timing on these cars. And if you left the distributor loose it could have retarded itself while the motor was running. Always lock it down after you set it.
A weak fuel pump problem generally won't crop up at idle or modest throttle- it'll usually fall on it's nose when you are at WOT in the upper RPMs.
Old May 23, 2006 | 11:17 AM
Transmission: M5
Axle/Gears: 3.08
i changed the fuel filter its brand new with like 50 miles on it i also changed the timing to about 4* and yes it does this in every gear idk what the base timing is supposed to be but the electronic advance should take it over anyway right?
also it has a catback on it and it just sounds horrible there is no deep sound to it more like a popping sound but its not backfiring or missing it just dont sound right
Last edited by 25th rs camaro; May 23, 2006 at 11:26 AM. Reason: Automerged Doublepost
Old May 23, 2006 | 01:30 PM
GREEN WOLF's Avatar
Car: 1992RS CAMARO
Engine: 305TBI
Axle/Gears: 3:42
the catalytic convertor could be clogged ,give that a try!
Old May 23, 2006 | 02:01 PM
Damon's Avatar
The stock setting is 0* (and 4* advanced is perfectly acceptable as well, in my experience) but you need to remove all computer-supplied timing by disconnecting the timing wire BEFORE you shoot it with your timing gun. If you don't, you'll actually have the timing set very retarded from where it should be.
Please forgive if you're already aware of this procedure- I always mention it when talking about setting timing on a computer controlled motor.
Old May 23, 2006 | 09:50 PM
Transmission: M5
Axle/Gears: 3.08
ya i did disconnect it and it never hurts to ask anyway
Old May 24, 2006 | 12:06 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Other than the fact you have a 150K on it, that's where I'd start.
Old May 24, 2006 | 12:19 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Bro, I've been troubleshooting this problem for a year now! I bet that you can't do a burn out now. You can powerbrake it but the highest you can get is 1000 rpms. Try it you'll see what am talking about.
There is a chance of compression issues and it goes down from there.
The cure, really, is a crate motor. Don't even bother with the LO3. I've learned the hardway.
Here are things that made my car drive somewhat respectable again.
Flush the transmission and replace the fluid.
Replaced the sparkpluggs, put in a new distributor with new wires. Changed to a CD ignition (you could prbably skip that.).
The biggest thing that helped was adjusting the TV cable and bumping up the idle screw up quite a bit. If you bump up that screw up about 4 turns I am sure that you will notice improvement.
I've taken this thing to countless shops for inspection. Clogged cat was assumed to be the problem. NOPE.
I hope its just something simple, but it sounds awfully close to what mine did.
Good luck bro.
Old May 24, 2006 | 02:56 PM
Transmission: M5
Axle/Gears: 3.08
i have a 85 IROC 305 engine in the garage i was thinking about puting that in but idk. as im lookign at the injectors on the L03 the left side isnt spraying at all..... more of a drip so it is fuel related im geting the injectors flow tested and cleaned so if thats not the problem im hinking fuel pump
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
