Expanding Foam
Old May 24, 2006 | 11:23 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Expanding Foam
Is it safe to use it on fire wall?? i have a huge hole in my fire wall and its allowing water to puddle on passanger floorboard..
Old May 25, 2006 | 12:02 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I don't see why not.... what's the temp rating on it? I'd just be worried about it catching fire, but I think it's fairly high temp safe.
What's the hole from? I think you can get a rubber grommet/blockoff thingie for that, or use fiberglass resin/mat or peel-n-seal type of stuff.
Old May 25, 2006 | 04:27 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
It works, won't burn, but will turn nasty and start breaking up after a while. It also expands like MAD and will possibly end up where you don't want it. I highly do NOT recommend it unless you're using it as sound deadening in parts of the car that're hard to get to.
Old May 25, 2006 | 07:47 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
are you sure that it's not actually coolant and your heater core has gone bad?
Old May 25, 2006 | 08:50 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
im sure because it only pools when it rains heavly. No its not missing a gromet its abotu a fist sized hole
Old May 25, 2006 | 09:05 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
WIth that fiberglass mat, i hae to use the fiberglass bondo ehe? also it doesnt burn near heat riight?
Old May 25, 2006 | 09:30 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Do it right and block it off with a metal plate.
Old May 25, 2006 | 09:33 AM
Sonix's Avatar
Car: 1982 Trans-Am
...main question is, why do you have a fist sized hole?
fiberglass mat you'd use with resin, it'll cure rock hard. Not terribly structural, but it beats a gaping hole, and it's waterproof. No need for bondo, unless you wanted to smooth it out after and make it look like it never existed.
or you could do it the hard way, and weld a plate in.
Old May 25, 2006 | 12:34 PM
PonyKiller87's Avatar
Car: 87 Iroc Z28
Engine: 355 TPI
Thats what I did when I took my heater out, just flanged the hole and welded a plate in.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
777Shock777
Oct 29, 2015 04:30 PM
mfp189
Sep 27, 2015 09:25 AM
CD MaroMan 91
Car Audio
Oct 27, 2001 04:19 PM
GTA88
Sep 2, 2001 09:34 PM
