broken bracket...what to do
Car: 1991 Z28 (sold)
i am currently replacing my water pump and i noticed my power steering pump and alternator bracket (on the drivers side) is cracked. how the heck did this happen? the power steering pump leaks but i dont think it has anything to do with the bracket. i havent noticed any problems with belts slipping or any noises. i really dont have the money to fix this right now, how long can i go? could i have someone weld it?
all the coolant is from removing the water pump
But do you really think that would be cheaper, easier, or better than just going to the junkyard and picking up another one? There's about a billion of those out there on TBI trucks.
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
it's really really really easy to replace. I have to fix/replace mine come to think of it- I have the same problem you do! Don't over-tighten the bolts!
I'm going to weld it all up, drill the hole back out, then sandblast and paint the whole thing black or silver.
well how long should i let it go like this? i cant weld, i would have to get someone to do it for me. will i be able to find this at a parts store or chevy dealer? i cant stand the junkyards around here...impossible to find anything
i couldnt get the alternator support brace thing to fit after i put on my headers so i left it off. is this why it broke? what can i do to prevent this from happening again? is it possible to find a stronger aftermarket piece?
how do i get the pulley off the power steering pump?
so yea its friday and i need to know if i can find a stonger aftermarket piece or get one from the dealer before they close for the weekend
and what made this happen? how do i get the pulley off the power steering pump, do i need a press? does the pulley need to be removed before i can take off the bracket?
i really have no one for advice on this situation except you guys so any help is appreciated
Take Sofa's advice and get a recycled replacement. Then put the brace back in place. If not, make sure they have a few more in the bone yard.
The P/S pump sheave is pressed on the shaft. You can use a portable press (looks like a puller, but specifically made for alternator and PS pump sheaves).
what can i get in the way of an aftermarket bracket(s)? Will i need that alternator-to-manifold brace if i get an aftermarket bracket?
ive been looking and it seems i can only get a power steering pump and alternator bracket seperately....im woried about it not fitting, does anyone have any part numbers?
i kind of want to avoid using a stock bracket because i dont think i can make that alternator brace work
thanks for any help
thanks for any help
broken bracket
I'll Tell you one think that might work and you can do it your self is to use a welding rod called alumaloy or something like that and a propain torch I have used it on just about ever thing and it works great as long as it is aluminum and not a aluminum alloy you see it advertised on TV with a little machine work its hard to tell were the repair was. I have also have picked up rod at a welding supply shop for aluminum alloy you have to use a oxygen acetylen torch for more heat the people at the supply shop can help you. I know it might be a hassle but that is one skill when you learn it will help you a lot in the future in building your rod.
i might get a new bracket for 82 bucks from GM. i dont care about the price, i just dont want it to break again. will going without that brace cause it to break again?
no green
Jan 9, 2016 09:22 PM
