AC compressor doesn't turn on. What are the possibilities?
Old May 26, 2006 | 11:54 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
The compressor doesn't turn on, not even intermitantly. I'm trying to figure out what could cause it and how to test each one so I'm not just throwing parts at it.
No refrigerant (depress schrader valve and see if anything comes out, I don't have a gauge)
Bad Wireing (isn't their a way to hotwire the compressor?)
Bad Compressor (?)
A switch?
Old May 27, 2006 | 12:52 AM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
clutches on theses models love to go bad id say faulty compressor or no refridgerant most of the wiring is protected
Old May 27, 2006 | 08:25 AM
Vader's Avatar
This is common in systems which have lost charge. You can test this without releasing more refrigerant but temporaroly installing a jumper in the connector for the low pressure cutout switch.
Start the engine, set the controls to cold and A/C, install the jumper, and see if the compressor clutch pulls in. If so, remove the jumper quickly so that you don't run the compressor too long without oil charge.
If the clutch does not pull in with the jumper installed, remove the electrical connector at the clutch and check for 12V across the terminals in the connector. If voltage is present, you may have a failed clutch coil. If no voltage is present, you likely have a switch or control problem upstream.
Old May 27, 2006 | 08:55 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Thank you very much for the help, it's greatly apreciated.
I did what Vader suggested the low pressure switch didn't start the compressor.
The connector had 12v.
But when I reinstalled the connector (engine running) the compressor kicked on for a second. Wiggle the connector around a bit and the AC is running. It runs, will shut off, jiggle the connector and it's back on. Clean and bend the prong and it's back in buisness.
It is cycling on and off though, I'm guessing that's just a matter of a low charge though.
Fronzizzle
Mar 18, 2019 08:29 PM
Derick15
Sep 17, 2016 05:28 PM
Fronzizzle
Aug 17, 2015 02:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
ZsTransAm
Aug 11, 2015 07:30 PM
