Engine Idles fine, runs crappy, no throttle resp
Old May 29, 2006 | 03:40 PM
scanman717's Avatar
Car: 92 Z/28 Convertible
Engine: LB9
Transmission: Mad Dog Auto 700R4
Ok here's the deal.. I have been having trouble with the car starting.. Checked the battery, dead cell, so I replaced it. Voltage check on Alternator showed low volt output, so I replaced it. Also replaced negative battery cable and put in a Hitachi starter for good measure. Still the starting was an issue.. If I let it sit for a couple of days it would take a while cranking to get it going. So I checked and the timing was a bit off, so I set it to 2btdc It now starts and idle's fine. But when I go to drive down the street it hesitates.. When I mash the throttle it does nothing, takes like 2-3 seconds before it starts to accelerate, then it is more of a 4 cyl. acceleration, than the 305 that's in it...
As of 3-4 months ago, new fuel injectors, new MSD cap, rotor, wires, Bosch sparkplugs.
Also, hooked up the trusty Datamaster laptop... The only 2 things that stuck out were, LTerm-P Percent = -15.6 and MAP = 71.6 both at idle.
Thanks for any insight.
Old May 31, 2006 | 05:53 PM
Todd Chastain's Avatar
Car: 87 iroc z28
Engine: 5.7 TPI
check your fuel pressure. could be your feul pump going out, mine's doing the same thing, bad fuel pump.
Old May 31, 2006 | 10:02 PM
scanman717's Avatar
Engine: LB9
Oh, good thought... I will have to get a guage and check that when I get home... Too bad it wont be til the end of June Working sucks, but I got to pay for the toys somehow
Old Jun 1, 2006 | 09:16 PM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
Hey Scan,
This may sound absurd, but have you checked your fuel injector fuses? I had a very similer problem: hard starting, slow acceleration, etc. and I was going crazy until by pure chance I noticed that my F*****G brother "borrowed" a fuse from my fuse block for his firebird, which was one of my injector fuses. I replaced the fuse and the car ran great. Couldn't hurt to at least take a look. Sorry in advance if I wasted your time.
Old Jun 1, 2006 | 10:41 PM
scanman717's Avatar
Engine: LB9
HAHA... Thank god, I don't have any brothers that live close to me..
I would think that would have thrown a SES light?? Anyhow, thanks for the tip, not wasting my time at all.. Just wish I could try it right away and let you know..
When I eventually get home from this aweful business trip to New England, I will try all the suggestions.. Thanks 87IROC!!
Old Jun 2, 2006 | 11:56 AM
Car: 87 IROC
Engine: 5.7 TPI
Nope, it didn't trigger a code, but good luck.
Old Jun 4, 2006 | 09:52 PM
scanman717's Avatar
Engine: LB9
Just posting my own thoughts to check myself when I finally get home:
Fuel Relay
Fuel Filter
Injector Fuses
Fuel Pressure
Fuel Pump
Throttle position sensor??
Old Jul 4, 2006 | 01:16 PM
scanman717's Avatar
Engine: LB9
Now, I'm really getting frustrated....
Still the same problem.. No throttle response.. I mean I have to pusht the pedal to the floor to get the thing to start crawling... Engine seems to idle fine. No engine codes or anything..
I have done the following:
Replace Fuel Filter
Checked injector fuses (a ok)
Checked Fuel Pressure (it failed originally, and was diagnosed according to the service manual to be the FUel Pressure Regulator I replaced it and it is fine now)
Fuel Pressure holds at 41lbs.....
So what else can be wrong???????? Please help, I am going nuts and the wife is hounding me to buy a new car!!
Old Jul 19, 2006 | 08:19 PM
scanman717's Avatar
Engine: LB9
So.. I am still stuck... I put new fuel injectors in a few months ago, no problems, but the originals had 130k and so I thouhgt for good measure I would replace. What would happen if the fuel injectors are wrong??
I was told to get Ford 22# that matched the fuel flow of the factory Delco 19#. Would that cause the bogging that I have????
Old Jul 20, 2006 | 09:46 AM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
Transmission: 700r-4
i hear you
ive got the same problem mine is fuel pump related though but i still get lots of pressure
Old Jul 20, 2006 | 01:11 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
what about a vacuum leak . When mine had one the throttle was mushy. But it wouldn't hold an idle without some throttle input.
Old Jul 21, 2006 | 06:48 AM
nathanielehlert's Avatar
Car: 1986 Camaro Z28
Engine: 305 TPI i might be a 350
Axle/Gears: Stock
i had an 88 camaro and my problem was the fuel pump or the relay my firebird started doing the same krap about 4 months after i got it but that was a relay
does it happen under load or at all times
Old Jul 21, 2006 | 08:05 AM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
for me i can't do a brake stand because it wont make power. rpm just wont spin up like it should with a carb. same when im driving just not getting it
Old Jul 28, 2006 | 08:08 AM
scanman717's Avatar
Engine: LB9
Well, I found my problem last night.... My distributor was "walking". I had a friend suggest the timing chain maybe stretched (and it still could be). So I checked the timing and it was all out of whack. I checked the distributor and a tick mark I had made as a reference several months back was off where it should have been. I could barely move the distributor with both hands. Loosened the bolt and reset the timing to 8 and it purrs like a kitten!!
Not sure if maybe I didn't tighten it all the way the last time or what...
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
camaro71633
Sep 1, 2015 10:24 AM
db057
Aug 22, 2015 08:17 PM
squiggy2
Aug 9, 2015 09:30 PM
