intake maifold
Old May 30, 2006 | 06:50 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
intake maifold
im about to change my intake manifold, when i remove Distributor, do i got to make the sameplace when i remove it, and its it hard to change, i was planing on doing it this weekend, can i get any feed back thanks chris
Old May 30, 2006 | 06:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes, it should be put back in the same position as it was in when it was removed.
Old May 30, 2006 | 06:53 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Here you go How To Install an Intake Manifold
Old May 30, 2006 | 06:54 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
when i remove it , if the bottom piece dont move i can put it right back in with no problems
Old May 30, 2006 | 07:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The rotor will turn as you pull it out because of the angle ground into the gears.
Old May 30, 2006 | 07:07 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
damn that sucks, i will wait for my dad to help me then
Old May 30, 2006 | 07:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's not that difficult. Take the cap off and mark the direction the rotor is pointing in. Then mark the position of the base relative to the car. When you reintall it, make sure that when it's all in, the marks still line up.
Old May 30, 2006 | 07:14 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
what do u mean by the the quote i made bigger and darker
Old May 30, 2006 | 07:24 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I seriously suggest that you wait for your dads help.
Old May 30, 2006 | 07:26 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
i plan to, i dont want to **** it up. so im going to wait,
Old May 30, 2006 | 07:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Well, if you were just reinstalling the distributor you'd make a mark on the distributor base and another one on the intake, and when you put the distributor back in you'd line them up.
That doesn't make much sense though since you're replacing the intake, so make a mark on the firewall or something to line the distributor base up with.
Regardless of how you do it, the timing will have to be set when it's all done. The marks will get you close though.
Old May 31, 2006 | 01:18 AM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Thats all correct, but if you miss the mark all you have to do is get the #1 piston to T.D.C.(top dead center) on the compression stroke check where the rotor is pointed in with the distrbutor cap off and then run your wires in the correct firing order.
Old Jun 1, 2006 | 08:24 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
me and my will be fixing it this sunday, and putting a cam in it also
Old Jun 1, 2006 | 08:36 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Originally Posted by jkwild0630
me and my dad is fixing it on sunday
ARE or WILL BE JK
Old Jun 1, 2006 | 09:08 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
Originally Posted by 82 Iron Duke
ARE or WILL BE JK
sorry igot kicked off
of aol
Old Jul 11, 2007 | 02:00 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: intake maifold
I taped down my rotor onto the base, as tight as i could, before pulling the dist. Next i made a mark, on the tip of the rotor, and one on the base. This way if there is any slack in the tape, and the rotor turns a couple fractions of an inch, its still marked.(so now the rotor is lined up with the base.)
Now put some tape aound the shaft of the distribuor and make a mark. If you arent removing the intake, make a mark on it, if you are, make a mark on the firewall.
Now you have the base of the distributor lined up to the engine.
Pull out the distributor, the rotor will not turn, because you taped it down, you will need to turn the distributor as you pull up. Look at the gears, you'll understand why.
Putting it back in, you cant slide it straight in, because of the gears. SO put it roughly where you think it should go. When its COMPLETELY SEATED, check all your marks, they should all line up. If not, youre probably off by a tooth, pull out and repeat until you get it.
the gear teeth are big enough, that if you are off by a tooth, its very obvious, you can really tell that it isnt lining up.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
