ALDL connector code reading
Old Jun 1, 2006 | 12:43 PM
Rosadoc-Z's Avatar
Car: 1987 Camaro IROC-Z
Engine: 350 5.7 TPI
I had the "SES" light come on and off on me a few times on my way back from work (20 min drive). WHen i got home i decided to try reading the code by sticking the paper clip into the ALDL but its not working. I'm sticking it into the A and B connectors but the SES light doesnt flash, not even the initial code 12. I've read codes for my other cars in this method but this is my first time doing it on a Camaro so maybe i was doing something wrong. Any suggestions?
1987 IROC-Z 5.7TPI 350
Old Jun 1, 2006 | 12:49 PM
Rosadoc-Z's Avatar
Engine: 350 5.7 TPI
oh yeah maybe i shouldve mentioned that none of the lights (e-brake, fasten seat belt, check oil, etc) dont work. Being that the SES light is grouped with those other lights i figured that it didnt work either until i saw it flashing today.
I've only had this car for a week so I havent had a chance to fix all these problems.
Old Jun 1, 2006 | 01:21 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Q: How can I display the error codes from a Service Engine Light?
A: If your car does not have the 12 pin DLC connector, you may not be able to manually "flash" your trouble codes. The language "may be possible" appears to suggest that this method should work with most, if not all, 12 pin DLC equipped cars.
THE CONNECTOR
----------------------- | 1 2 3 4 5 6 | | 7 8 9 10 11 12 | -----------------------
DISPLAYING THE TROUBLE CODES
Run a wire/hairpin from Pin 6 to Pin 12 with the ignition off (although on later cars it should be from Pin 5 to Pin 6), then turning the ignition to the on position without starting the engine will flash the "Service Engine Soon" light in the following sequence: flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause Following this "12" code repeating three times will come any trouble codes stored, flashing each of them three times. If you do not see the "12" flash three times, your diagnostic circuit is defective. Some vehicles will display stored trouble codes, then "12" again, followed by energizing "most system controlled relays." The fuel pump relay will not energize. The idle air control valve will fully extend to enable checking minimum idle speed.
CLEARING THE TROUBLE CODES
Turn the keyswitch to the off position. To clear any trouble codes, disconnect the power feed for 30 seconds. If this is done at the battery, and your car stereo is equipped and programmed with a four digit pin code, you may have to re-enter that as well to use your stereo again. A better place to remove power is at the fuse.
TROUBLE CODES
12.No reference pulses to Electronic Control Module (ECM).
13.Oxygen sensor signal stays lean during warm engine cruise
14.High temperature indicated at engine coolant temp sensor
15.Low temperature indicated at engine coolant temp sensor
16.High battery voltage OR Direct inition system open or shorted to ground
17.RPM signal problem
18-20.N/A
21.High voltage at throttle positon sensor
22.Low voltage at throttle positon sensor OR Fuel cutoff relay circuit open or shorted to ground
23.Low temperature at manifold air temperature sensor OR Throttle position sensor error
24.Circuit fault in vehicle speed sensor
25.High temperature at manifold air temperature sensor OR Vacuum switching valve circuit open or shorted to ground OR High voltage at ATS sensor
26.Fault in quad driver module
27.Fault in 2nd gear switch
28.Fault in 3rd gear switch
29.Fault in 4th gear switch
30.N/A
31.Low voltage at manifold absolute pressure sensor OR Fuel injector OR Park or neutral switch OR CAM diagnostic OR Governor malfunction OR Wastegate overboost OR Wastegate eletrical signal open or shorted to ground
32.Fault in barometric pressure sensor circuit OR Fault in exhaust gas recirculation valve diagnostic switch OR Fault in electronic vacuum regulator valve
33.High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
34.Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)
35.Idle speed can not be set to desired RPM
36.Burn off at mass air flow sensor OR Problem in transmission shift OR Fault in direct ignition system OR Missing pulses in electronic spark timing signal
37.N/A
38.Fault in torque converter clutch brake switch
39.Fault in torque converter clutch circuit
40.N/A
41.Fault at cam sensor OR Cylinder select error OR Tach input error
42.Fault at electronic spark timing circuit OR Fault at direct ignition system OR Fault at fuel cutoff relay circuit
43.Low voltage at electronic spark timing circuit
44.Oxygen sensor lean
45.Oxygen sensor rich
46.Fault at vehicle anti-theft sytem OR Fault at power steering switch
47.Problem at Electronic Control Module (ECM)
48.Misfire
49.Vacuum leak
50.N/A
51.PROM error
52.Problem at Electronic Control Module (ECM) - Missing fuel calpac missing OR Analog to digital converter error OR Fault at quad driver module OR Low voltage at oil temperature sensor
53.High voltage at battery OR High voltage at exhaust gas recirculation valve OR Voltage reference error OR Problem at vehicle anti-theft system
54.Low voltage at fuel pump OR Low voltage at Fuel pump relay OR Output failure at quad driver module
55.Problem at Electronic Control Module (ECM) - ECM failure OR Serial bus error OR Fuel lean malfunction
56.Low coolant or corrosivity OR Fault in port throttle system vacuum sensor
57.N/A
58.Problem at vehicle anti-theft system
59-60.N/A
61.Oxygen sensor degraded OR Port throttle system error OR Cruise control problems
62.Gear switch input diagnostics OR High voltage at oil temperature sensor OR Fault in cruise control- vacuum solenoid circuit
63.High voltage at manifold absolute pressure sensor OR Fault in exhaust gas recirculation valve OR Fault at right oxygen sensor
64.Low voltage at manifold absolute pressure sensor OR Fault in exhaust gas recirculation valve OR Right oxygen sensor lean
65.Failure at exhaust gas recirculation valve OR Faulure at injector peak/hold diagnostic OR Right oxygen sensor rich OR Fault at cruise control position sensor
66.Internal reset of Electronic Control Module (ECM)
67.Fault at cruise control switch
68.Fault at cruise control switch
69.Fault at air conditioner pressure switch
70-87.N/A
88.Internal reset of Electronic Control Module (ECM)
Old Jun 1, 2006 | 01:28 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
| 1 2 3 4 5 6 |
| 7 8 9 10 11 12 |
your port numbers will be in that order.
Old Jun 1, 2006 | 01:36 PM
Rosadoc-Z's Avatar
Engine: 350 5.7 TPI
ok, i've been doing port number 5 and 6. I'll try 6-12 when i get off work
Old Jun 1, 2006 | 09:14 PM
Rosadoc-Z's Avatar
Engine: 350 5.7 TPI
well i tried 6 and 12 and still doesnt work. Any other suggestions?
Old Jun 2, 2006 | 07:13 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Weird! Im havin the exact same problem as You.
Old Jun 2, 2006 | 01:10 PM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
Rosadoc,
Funny, I just replied to another one of your posts about your IAC. The correct connectors for our cars are "A" and "B", or according to this thread, 5 and 6. If you put the paperclip in the wrong connectors you could have a HUGE problem on your hands, possibly in the realm of needing a new ECU, so be careful. Before you begin, make sure your engine light is operational by turning your ignition to the "ON" position, not the "RUN" position. If the light does not come on with the ignition in the "ON" position, you need to fix this issue before checking your codes with this method. Obviously the the light needs to illuminate for this to work. You mentioned that you had seen the light flash a few times in the past, but it may only work intermittantly thanks to a loose connection or a chafed wire. Our cars are notorious for such issues. OK, turn the ignition off. Connect the jumper to the correct terminals(top right, and the one just to its left). Turn the ignition to the "ON" position, NOT "RUN". The engine light should flash code 12. If it doesn't, you have another issue that needs to be dealt with. One last thing, DO NOT START THE VEHICLE AT ANY TIME WHILE THE JUMPER IS CONNECTED. Hope this was helpful. Hope this helps you too, Rik. Good luck
Old Jun 3, 2006 | 12:05 AM
Rosadoc-Z's Avatar
Engine: 350 5.7 TPI
well i got bad news, the SES light doesnt come on when i got the ignition turn on (but not on run) and it doesnt flash code 12. So it looks like i got a bigger issue on my hands
Old Jun 3, 2006 | 09:56 AM
Car: 87 IROC
Engine: 5.7 TPI
It's a long shot, but before going any further, check your fuses. Could save you some effort.
Old Jun 3, 2006 | 11:31 PM
Rosadoc-Z's Avatar
Engine: 350 5.7 TPI
hopefully its something as easy as a blown fuse. Will check tomorrow morning
Old Sep 7, 2014 | 06:26 PM
Tri'all's Avatar
Car: would like to drive this 1987 iroc
Engine: 5.7 bored .030 over
Re: ALDL connector code reading
im a total nube to this site but can someone tell me why i can't get pictures uploaded on here? Im having issues with the no check engine light along with tail/ most clearance lights
Old Sep 7, 2014 | 10:07 PM
gm muscle's Avatar
Car: '89 Iroc-Z
Engine: 5.7 TPI
Transmission: 700 R4
Axle/Gears: 2.77
Try using a photo sharing site like photobucket and copy it on your post. See if that works.
Old Sep 7, 2014 | 10:13 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Check this out.
https://www.thirdgen.org/forums/tech...-pictures.html
Old Sep 7, 2014 | 10:40 PM
Tri'all's Avatar
thank you kind sir's i shall try this tomorrow most help I've gotten in responses on here so far!
Old May 4, 2019 | 06:35 PM
mdisav's Avatar
Did you ever figure out why seatbelt light, Check engine light, and e brake light would not come on? My check engine light will not flash either.
Old May 4, 2019 | 06:43 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Please be mindful of the thread date, some may suggest you start your own thread identifying your specific issue and members will happy to help. If the ALDL has been properly grounded then you should get a code 12 flash in addition to any other stored codes. I have the gmsm troubleshooting guide if you need it.
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
mdtoren
Aug 23, 2015 12:52 PM
chazman
Aug 22, 2015 02:01 PM
mizz0313
Aug 12, 2015 06:45 AM
