Head and manifold bolt torque specs
Old Jun 3, 2006 | 01:14 PM
Draekon's Avatar
Car: 1984 Firebird
Engine: 305 LG4
Transmission: Automatic
I'm currently replacing a head gasket on my '84 firebird stock (have it torn apart and cleaned the surfaces, ready to reassemble), but I need to know what to torque the head and manifold bolts to, and what order to do in it. Any help would be great.
Old Jun 3, 2006 | 02:22 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
here you go.
Attached Thumbnails Head and manifold bolt torque specs-head-bolts.jpg   Head and manifold bolt torque specs-intake-bolts.jpg
Old Jun 3, 2006 | 07:20 PM
Draekon's Avatar
Car: 1984 Firebird
Engine: 305 LG4
Thank you very much!
Old Jun 3, 2006 | 07:53 PM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Transmission: TH-350
Axle/Gears: Open...
I also recomend starting at page 3-55 in the Chiltons manual.
Old Jun 3, 2006 | 11:44 PM
Draekon's Avatar
Car: 1984 Firebird
Engine: 305 LG4
Thanks for the suggestion, but I'm gonna pass up on the manual, I shouldn't need it.
But one more thing, what should the rocker arms be torqued to?
Thanks again
Old Jun 4, 2006 | 08:01 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
the manuel is actually a really good investment. it does tell you about everything. the rocker arms are not tourqed. They are set. you have to get them to zero lash. and then give them and extra half turn.
Old Jun 4, 2006 | 06:15 PM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Axle/Gears: Open...
I thought you just tightened them down until the pusher doesnt twist anymore then tighten it down 3/4 of a turn?....enlighten me before i start the engine for the first time...
Old Jun 4, 2006 | 06:35 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Don't forget you need to spep toruque the manifold and the heads also.
Tom
Old Jun 4, 2006 | 06:45 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
yes you do need to roll them in your fingers until you feel that there is no more slop. that is zero lash then you need to do 1/2 to 3/4 of a turn more. but there is a sequence to it. only certain ones when the motor is on tdc number 1 and other ones when the motor is on tdc of number 6. I have a haynes and it is very useful when it comes to just about everything with the car.
Old Jun 4, 2006 | 06:52 PM
Draekon's Avatar
Car: 1984 Firebird
Engine: 305 LG4
Chilton's manual says zero lash and then 1 more turn (I know I said I wasn't going to get a manual, but thats because my dad is instructing me and he said we didn't need one, but he finally decided that it might be smart)
Also, in the manual with the rocker arms, it says with it at x position, y valves can be tightened.
In regards to my reassembly, everything was going good until trying to put the intake manifold back on. One of the bolts doesn't want to go in the hole, and I dont know where 2 of the brackets that I put with the manifold bolts go. The manual doesn't help much when I could actually use it :P
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
