Where psi does your oil pressure sit at?
Old Jun 4, 2006 | 03:09 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
I am thinking that maybe the reason why my car acts the way it does is because of the oil pressure.
When it first start up it sits at about 40 psi, then as the car heats up, it drops below 30 psi and stays right at the first tick after the red ticks.
I change my oil on time every time, I dunno if this is good or bad. I also use the high mileage oil 10W30...
Old Jun 4, 2006 | 03:52 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
That's where mine sits. I believe that's the appropriate level when the car is at idle.
Old Jun 4, 2006 | 04:43 PM
357mag's Avatar
Car: 94 C1500
Transmission: NV-4500
Axle/Gears: 3:42 10 bolt 8.5"
Most GM smallblocks are spec'd at about 18 psi at idle + or -. I don't put a lot of faith in factory gauges, so if you have access to a decent calibrated gauge, plug it in and see what it's really reading, then check your dash gauge at the same rpm, then you can figure out about where your dash gauge reads re: a calibrated one.
Tim sends
Old Jun 4, 2006 | 04:53 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
my gw 350 stays at 50.
Old Jun 4, 2006 | 05:43 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
I use a 20-50 multi weight oil(for highmileage)
they're about 3.5bux a quart,
and i add 2quarts of Lucas Oil Stabilizer..
my car has almost 190k mileage on it,
when I used to use 10-30 regular oil,
my psi would sit 20 or lower on hot idle.
now with the oil stabilizer and the thicker oil i use,
I get 30+ at hot idle,
now i added a universal engine oil cooler hooked up..
it stays at 40psi at hot idle.
Old Jun 5, 2006 | 10:30 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
My gauge reads 0 idling in gear hot, 10-30 oil. It never makes any noise and is coming out soon anyway, its 165,000 miles old, I would'nt worry about it.
Old Jun 5, 2006 | 10:39 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
10psi per 1000RPM is kindof the general rule of thumb.
For pressure to drop at idle or low RPM is normal.
My old motor would drop into the red at idle. The new motor has never dropped below half on the gauge.
New motor now runs castrol full syn 10w30
Old Jun 5, 2006 | 12:15 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Idle 35psi
1200+ 47psi
15-40 rotella
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
