Bad Wheel Bearing?
Old Jun 5, 2006 | 09:48 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Bad Wheel Bearing?
What noises do wheel bearings do when they are on their way out? My car makes a squeeking noise from the front left wheel when I turn left. Only sometimes it does this and only when the brakes are already warmed up. Im hoping its not a wheel bearing but just the brakes rubbing when I turn.
Old Jun 5, 2006 | 09:51 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
It sounds like the brake pad to me. I have never seen a wheel bearing give any warning exept for the grinding noise when they are already broken.
Old Jun 5, 2006 | 10:09 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
could be a bearing.
Their cheap and relatively simple to replace.
You should check into it before your tire passes you down the highway...
Old Jun 5, 2006 | 11:06 PM
1981LT1's Avatar
Engine: LT1; LT1
True. It only takes a couple of minutes to do an inspection of the bearings just to make sure.
xxx3man`
Sep 23, 2015 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
Dialed_In
Aug 20, 2015 01:45 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
