Fel-pro 1-piece oil pan gasket problem
Old Jun 7, 2006 | 08:37 PM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
I have a 1 piece rear main seal block and I bought a 1 piece oil pan gasket ( Fel-pro 1886) that I thought would work. However, when I went to install it tonight the oil pan wouldn't fit down on the timing cover section. I thought something else was interfering with the pan, but I doubled checked my clearances with the pickup and it was fine. The gasket seems to be too thick? I belive the front and rear thicknesses on the old style is 1/4" and the newer ones are 3/8" (someone please correct me if I'm wrong). So I measure the rear portion and it checked out 3/8" thick and then I measured the front part 5/8" thick. I don't believe this right. Aren't the gasket's supposed to be 3/8" thick on both ends? Thanks.
Old Jun 7, 2006 | 08:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The "thick" and "thin" front seals are for the pans on 2 piece RMS blocks. The 1886 is supposed to be the gasket for all 1 piece RMS pans.
Old Jun 7, 2006 | 08:47 PM
cvpde37's Avatar
Thomas, Fel-pro makes two different one piece gaskets for the small chevy. One with a thick front seal and one with a thin front seal. The thick front seal is commonly used with the aftermarket front covers. It sounds like you got the thick and need the thin. I don't remember the part numbers, but if you check the Fel-pro catalog I'm sure it would clarify it for you.
Old Jun 7, 2006 | 08:54 PM
Car: 1986 Iroc
Engine: Afr 408
Well, then something isn't right. Possibly the oil pan? Its just not fitting over the seal. The oil pan is supposedly for a 1 rms, could it actually be for a 2 rms? I mean would any other dimensions be different except for the seal depths? It seems to fit fine (another great ebay purchase). I started to think it might be for a 2 rms after awhile.
Old Jun 7, 2006 | 09:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What side is the dipstick on?
Old Jun 8, 2006 | 05:31 AM
Car: 1986 Iroc
Engine: Afr 408
Dipstick is on the passenger side.
Its either the pan or the gasket that isn't right.
Old Jun 8, 2006 | 06:09 AM
Car: 1986 Iroc
Engine: Afr 408
Doing a little more research and I found out that Fel-pro does have 2 different part numbers for the 1pc rms blocks. #1886 (which I have) and #OS34500R.
For the 1886 description: (taken right from their site) "1986-97 w/ 1-piece rear main bearing seal, GM Bowtie short deck block, Non-cnc bow tie block w/2 piece seal adapter. Thick front seal, R.H side dipstick."
The OS34500R seems to be more for stock replacement, but it is a 1 piece rubber gasket, I can't find much on a description.
So I can't rule out that the gasket is wrong. I'm going to try to get the OS34500R gasket and see if that works. If it works great, if not, I'm out $30, but I know the pan is wrong. Process of elimination...
Old Jun 8, 2006 | 09:47 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
OS34500R is a kit that comes with a couple of other things. The actual pan gasket itself is probably the same, but you never know.
Old Jun 15, 2013 | 10:48 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Fel-pro 1-piece oil pan gasket problem
I know this thread is old as dirt, but I'm having the same issue.
Got a 1988 block, new timing cover from Canton, which assured ne it was the correct cover for my year, and a new oil pan from jegs listed for a 1986 and up block.
Got a one piece oil pan gasket from acomplete fel pro kit for a tpi 350.
The front seal is way too thick.
What seems odd too me about the os34500r is it is $10 cheaper then the 1886 gasket.
Since my pan gasket came as part of the kit, I can't say for sure if it is a 1886.
The kit I have is KS 2664.
The block and pan are both right Gand dipstick type.
Old Jun 15, 2013 | 11:23 AM
Car: 1971 Camaro
Engine: 427
So after searching the world, I went back out and decided to see if it would tighten.
And yes it does. The Gasket fits after you draw the pan down with the bolts.
Studs are a wise choice for the hardware, IMO.
Old Jun 15, 2013 | 11:56 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
I think the factory had studs at the corners for some reason. I don't know if all 1 pc RMS blocks had them but all of my pans have them.
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
