rtv oilpan gasket
Old Jun 8, 2006 | 06:05 PM
az_brent's Avatar
Car: 1985 firebird s/e
Engine: 388ci stroker
Transmission: stock, t-5?
rtv oilpan gasket
on my firebird i used little rtv sealant on the whole rubber oilpan gasket...stupid yes...now im leaking on the passengers sidehttps://www.thirdgen.org/forums/images/smilies/go%20crazy.gif
and have to drop the pan....what do you guys think of just using rtv sealant on the pan insted of placeing a **** load of rtv sealant on teh pan and block?
Old Jun 8, 2006 | 07:21 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
how bout not using rtv?
Old Jun 8, 2006 | 07:55 PM
ede's Avatar
ede
try a one piece oil pan gasket, they're pretty much bullet proof.
Old Jun 9, 2006 | 01:32 AM
az_brent's Avatar
i have a one peace gasket on there currently...but i used a rubber gasket on my timing chain cover too but there is so much oil in the way its hard to see where its all commin from and i only can look at it at night. but the oil starts on the passengers side by the lower raidator hose and continues down underneith the car....im just tryn not to freak out bout everything ive done wrong
Old Jun 9, 2006 | 09:38 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Do you have a bolt in the upper boss (of 2) located on the front lower passenger corner of the block? Originally it was for the engine mounts in '55-'57, has been left there even after going to side mounts. The upper bolt hole on the passenger side goes to the fuel pump rod bore, and if you don't have a bolt in there, you're going to dribble oil down the front of the engine.
Through '87 at least (nor sure about serp system), those bosses were used for the A.I.R. pump bracket. People who remove A.I.R. often don't realize that a short bolt needs to go back in there to plug the oil path. I put Teflon thread sealant on it myself, just to be sure it didn't leak.
Old Jun 9, 2006 | 11:33 AM
az_brent's Avatar
no i have no bolt there...hmm ill have to look at that...the block is from a early 70's corvette. but is it located in frount in the corner next to the fuel pump mount?
Old Jun 9, 2006 | 12:13 PM
az_brent's Avatar
sorry i had to ask that dumb ??. but with the right amount of oil pressure id get a good amount of seepage through the boltholes right?
Old Jun 9, 2006 | 12:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There isn't pressurized oil behind any bolts, but it can wick through over time if you don't use a thread sealer.
Old Jun 9, 2006 | 12:22 PM
az_brent's Avatar
there arent ne bolts there though ive used thred sealer on all my other bolts tho...i didnt kno that leaving the bolt holes unplugged would cause me harm unplugged so i didnt think about putting ne boltin in them.
Old Jun 9, 2006 | 12:29 PM
az_brent's Avatar
here is a pic of the engine...i plugged the fuel pump area but i left the bolt holes (shown) without any bolts in them where the smog equip. would go
Old Jun 9, 2006 | 01:54 PM
five7kid's Avatar
It isn't a pressurized passage, just the oil that drips off the fuel pump lobe and down the rod bore.
It's the upper bolt in your picture. Since you aren't running a mechanical fuel pump, you don't have to worry too much about how long the bolt is.
Thread sealer is insurance, not absolutely necessary.
Old Jun 9, 2006 | 04:08 PM
az_brent's Avatar
alright ill have to take care of that then. one minor problem down one big one still to figure out lol
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
