350 heads on a 305?
Car: Sold my Thirdgens, want another one
Engine: L98/TPI
Transmission: 5-speed
Axle/Gears: 3.45
350 heads on a 305?
will 350 heads on my 305 lower my compression ratio? what are some benefits/disadvantages to putting 350 heads on a 305?
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
from what everyone has told me no 350 heads work on the 305 apperently something is differant about a 305 compared to other small block chevys like 302/350 and the like
as you note when looking in any parts books 305 heads are listed seperatly from all other small blocks
and i still havent found anyone that made 350 heads work on a 305
i was going to get vette 350 alloy heads but was told they wouldnt work by mechanics and just about every one i know and being that the zz4 heads are the same as the vette heads that most likey isnt a good idea
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
all 350 heads will bolt onto a 305. You have to watch out on the valve lift because the larger valves can and will hit the cylinder bore.
Other than that most of the 350 heads have larger (and sometimes much larger) chambers which drops the CR drastically unless you are going to use domed slugs.
Car: 1991 camaro RS
oh i knew they would bolt up but that was one of the problems the valves would hit the pistons and also the compression
that to me made me shy away from 350 heads
Guest
Posts: n/a
Well whoever told you 350 heads wont work on a 305 was wrong.
There's a ton of people on this board who have used 350 heads on a 305. Its not rocket science. However due to the typical loss of compression ratio, I wouldnt advise it for most people. The ones that will find them useful are those changing the pistons while they are at it.
Engine: L98/TPI
Axle/Gears: 3.45
thanks for the quick replies guys! so from the sound of it, 350 heads arent really an option for me. im on a really tight budget, i just know that 350 heads are plentiful and relatively cheap. looks like i should stick with my own breed.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
the over hang from the large combustion chamber could possibly cause hot spots and detonation. the best way to lower compression in a 305 is to run dish pistons and a good .041" head gasket. also, you may want to check out the 113 casting aluminum vette heads. they disipate heat a bit better and will allow you to run more boost on the same static c/r cause they have the same 58cc combustion chamber.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
judging by the budget, i'm guessing you aren't doing forced induction right?
You just wanted better performing heads for your 305? Better than your TPI heads? 416's or 081s would do the trick, port 'em up!
NinjaNife
Aug 23, 2015 11:49 AM
