long block vs. short block
Old Jun 15, 2006 | 08:22 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
whats the difference between a long block and a short block? pros and cons? and what do i want for a mild street engine?
Old Jun 15, 2006 | 08:28 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
It have nothing to do with the performance of the engine, it has to do with what comes with the engine.
A long block usually consists of a block, crank, rods, pistons, cam, lifters, pushrods, heads, valves, rockers, and a balancer.
A short block is usually just the block, crank, rods, and pistons.
As for a street engine, the setup I have in my sig is very streetable, a little on the obnoxious side, but I do drive it will little problems from it. I run a mixture of 1/3 93 octane gas and 2/3 E85 (which is roughly 105 octane), or I will run straight 100 octane race gas, but it is a drive to get race gas. I can run higher octane but prices and distance keep me away from it.
Old Jun 15, 2006 | 08:30 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
normally long blocks come from oil pan to heads... every now and then you get an intake manny.. shortblocks have nothing but bottom end thats why they are cheaper
Old Jun 15, 2006 | 09:18 PM
johnnyboy's Avatar
well that's good to know, so if i'm planning on having an engine built all i really need to get is a block and a rotating assembly.
Old Jun 15, 2006 | 09:59 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
If you're plannig on having an engine built you really need to get some books to gain some understanding first. Otherwise chances are you are going to be taken for a ride.
Old Jun 15, 2006 | 10:18 PM
johnnyboy's Avatar
that's what i'm doing, but the guys at the shop that's gonna build it are friends so i'm not worried about it
Old Jun 15, 2006 | 10:39 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
If you just want a low power daily driver grab the longblock assembly, it will save you some cash.
If you want to have a motor 'built up' get the shortblock assembly. That way you wont end up buying 2 pairs of heads or 2 cams...
Old Jun 16, 2006 | 06:41 PM
johnnyboy's Avatar
i'm looking for an easy 350-400hp
Old Jun 16, 2006 | 06:52 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
For the 400hp mark you will need some carefull parts consideration. It's not hard to do you just have to get the right parts and the proper assembly.
Old Jun 16, 2006 | 07:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you want a complete drop in engine, ready to go, except for a few minor things, then you buy a long block. If you already have good heads and induction system for an engine, then you buy a short block and install your parts to finish the engine.
Street Lethal
Apr 30, 2019 12:14 PM
gixxer92
Sep 1, 2015 04:32 PM
camaro71633
Sep 1, 2015 10:24 AM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
BBSDesigns
Aug 11, 2015 07:39 PM
