Routine maintenance gone bad
Old Jun 17, 2006 | 11:37 PM
recaroguy's Avatar
Old Jun 18, 2006 | 08:36 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i'm thinking a bad connection or a spark plug wire on backwards if you took them off the cap
Old Jun 18, 2006 | 09:39 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Do NOT use dielectric grease under the module, use the right stuff, thermal heatsink compound. Many of the box store modules come with the dielectric crap. What you want is the white or silver colored stuff.
Wells part # SL-203. And make sure the parts boys give you both tubes in the box, lately I've had the parts boys pulling out one tube from the box and trying to charge me the full price. It should be two tubes in the Wells box, IIRC blue and white box.
Old Jun 18, 2006 | 01:46 PM
recaroguy's Avatar
Old Jun 18, 2006 | 03:32 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
I still bet you have a wire crossed. Or a frayed module wire that is now exposed.
Old Jun 18, 2006 | 03:41 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
it's possible that you broke the plug wire inside the insulation by moving things around.
also, check and recheck firing order...it's an easy one to screw up.
Old Jun 18, 2006 | 09:00 PM
recaroguy's Avatar
Old Jun 18, 2006 | 10:14 PM
mw66nova's Avatar
Engine: 7.0L
fuel filter?
Old Jun 18, 2006 | 10:18 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Same thing happen to me, turned out that while I was back there, one of the vacume lines (rubber) broke. I replaced the old line and all is well. I found the vacume leak by opening the hood while the engine was running. Found the leak quickly, it was hissing real bad.
Old Jun 19, 2006 | 09:50 PM
recaroguy's Avatar
Old Jun 19, 2006 | 10:28 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
I hope you didn't get a case of cease-fire.
And as I mentioned, don't use dielectric grease, it's not meant for that application, but if you have a choice between that and nothing, don't go with nothing.
Old Jun 19, 2006 | 10:42 PM
recaroguy's Avatar
Old Jun 19, 2006 | 11:20 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Cease-fire is another name, for an all too common condition, of cross-fire.
As for what it could be... :shrug:. Were the plugs wired properly before? I say this because I have come across quite a few cars where the firing order is shifted due to idiots installing the dizzy.
Did you check the timing? Did you verify #1 TDC again? Sure you didn't poke it in on #6 fire? (coil in cap?) If so did you make sure you had the ground strap in there? You can always have the module tested. I'd also chase all the wires back there and see if anything didn't come loose farther down, etc. Good luck!
Old Jun 19, 2006 | 11:25 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I bet him playing with the Ign module and wire, he F'ed up the pickupcoil inside the distributor.
Old Jun 20, 2006 | 09:40 PM
recaroguy's Avatar
Old Jun 20, 2006 | 11:02 PM
mw66nova's Avatar
Engine: 7.0L
did you try to set the timing after you noticed it was way out?
Old Jun 21, 2006 | 06:52 AM
recaroguy's Avatar
Old Jun 21, 2006 | 08:31 AM
mw66nova's Avatar
Engine: 7.0L
well, if you had to take the dizzy cap off, you probably turned the dizzy to get the hold downs off...this would totally screw up the timing.
Old Jun 21, 2006 | 06:21 PM
recaroguy's Avatar
Old Jun 21, 2006 | 08:14 PM
mw66nova's Avatar
Engine: 7.0L
it doesn't matter if the hold down bolt is loosened or not, if you turned the distributor to get to the back hold down latches on the cap, then turned it back after reinstallation of the cap (which you posted you did a few times) then the likely hood that you got the distributor back in the same spot is pretty slim. what happens is you move the body of the distributor, which moves the cap. that moves the terminals inside the cap in relation to where they ought to be struck by the rotor....thus your timing being off.
Old Jul 11, 2006 | 06:14 PM
recaroguy's Avatar
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
gta892000
Sep 16, 2015 12:40 AM
