Best mini starter?? Starter weight?
Old Jun 22, 2006 | 02:36 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Read some old posts, but would like to hear from some current users.
Any recommendations on which to look into that work for stock applications?
Any idea how much a factory starter weighs in comparison to these?
Old Jun 22, 2006 | 05:37 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
use a starter out of a 96+ truck or suv. they are the same design as the lt1 starter, but for 168 tooth apps.
Old Jun 22, 2006 | 06:30 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Im using one out of a 96 LT1 Vette and its working great at least half the weight of stock !!!
Old Jun 22, 2006 | 06:41 PM
Car: '89 GTA
Thanks for the replies guys.
Any idea how much they weigh? Stock or other?
I do need a 168 tooth for the factory application, right?
I'd prefer a new A/M one, but I'll keep the LT1 style in mind.
Old Jun 22, 2006 | 06:44 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
LT1 starter It's SOOOOO small
Old Jun 22, 2006 | 07:40 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
the stock weighs about 22 pounds, i got one from summit that weighs 14 pounds for $140 they have lighter but they are more expensive.
Old Jun 22, 2006 | 07:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Powermaster starters. The XS torque is one of the better ones.
Old Jun 22, 2006 | 09:12 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
yeah, CSR makes some that are like 8 lbs
Old Jun 22, 2006 | 09:27 PM
Car: '89 GTA
Good stuff, I'll look into all of those.
Old Jun 23, 2006 | 11:51 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I've had good luck with both Powermaster and CSR. I'd say the quality is a little better on the Powermaster though.
Old Jun 23, 2006 | 12:01 PM
Powermaster is a Hitachi starter motor. Nothing special there. About 2/3 of the aftermarket mini-starters use the Hitachi motor. The other third uses the Nippondenso motor. All that the different brand name means, is who made the aluminum adapter block on it, to mate it to our engine. They don't "make" the starter itself.
I have a CVR (ND); I have a friend with a Tilton (Hitachi). Both work great. Both are somewhere in the 10 lb sort of range, as opposed to the stock 20ish.
Jsut about ANYTHING is better than the ancient Delco direct-drive POS from the Stone Age that these cars came with. Including the newer Delco gear-reduction units, like the LT1 one.
Old Jun 23, 2006 | 02:18 PM
Damon's Avatar
GM makes a high torque gear reduction mini starter for the big block crate motors that also works on SBC 168 tooth applications. It's nice, but expensive (I have one). If you look at that 96-up Vortec starter it's looks just about identical to the GMPP starter but costs less than half. It could be the best starter GM ever built.
Old Jun 23, 2006 | 02:25 PM
Car: '89 GTA
Do you guys have some part #'s for any of these?
Powermaster, CVR, CSR, Tilton?
Summit the best place?
Old Jun 23, 2006 | 02:33 PM
mw66nova's Avatar
Engine: 7.0L
seriously...check ebay. just type in "starter sbc"
Old Jun 23, 2006 | 05:42 PM
Car: '89 GTA
Does it matter if it is staggered or inline?
Adjustable mounting block needed?
Old Jun 23, 2006 | 05:53 PM
mw66nova's Avatar
Engine: 7.0L
adjustable mounting block is cool if you ever go with some big nasty headers that might need extra clearance by rotating the starter body.
most likely you need an inline bolt pattern, not the offset (unless your running an older style 400sbc or the like.)
Old Jun 24, 2006 | 07:01 AM
chesterfield's Avatar
Car: Pontiac
"Any recommendations on which to look into and work for stock 168 tooth applications?"
"I do need a 168 tooth for the factory application, right?"
In an 89 GTA 350? I don't think so.
Old Jun 24, 2006 | 10:30 AM
Car: '89 GTA
soooo which would i need bud?
Old Jun 24, 2006 | 11:03 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
lots of starters show they work with both tooth counts. I run a hitachi brand on mine i picked up at work, it weighs around 8lbs, around 100 bucks, psl-100 part number
http://www.partsamerica.com/ProductD...tnumber=PSL100
Old Jun 24, 2006 | 11:10 AM
Car: 1988 IROC-Z
you should have a 153 tooth flywheel in your car is it's a stock L98. that is assuming it hasn't been swapped once in it's lifetime. a 96 LT1 starter works great. as mentioned it is agear reduction starter. not sure of the ratio but they give your car a new car type start and start up quicker. i hated they way my sounded when it started up. not ne-more.
Old Jun 24, 2006 | 11:24 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
Says 9.7 lbs. That probably includes the box and popcorn though, right? 7.5 lbs. I stand corrected!
Old Jun 24, 2006 | 11:39 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
it hasnt failed me in all the hard non start condition smy car first had when i cranked it over many times.
Old Jun 25, 2006 | 03:47 AM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
You need an inline bolt pattern for a 153 tooth flywheel. I have a Powermaster XS Torque, they are very nice.
Old Jun 25, 2006 | 09:47 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Most of the mini's will fit either tooth count since they come with a few different holes in the adaptor body. The Tilton super starters will work on both and being able to re-clock the starter is a life saver. Ive had quite a few different brands, quality and reliability has never been an issue with either NP or HT.
Old Jun 25, 2006 | 02:37 PM
Car: '89 GTA
Gotta love this site, never fails me.
Thanks for the input folks.
Mine starts up "ok", but if I can get a nicer start and shave off 10lbs from the heavy piece of junk on there now, I'm sold.
I'll compare a few brands then add it to "the list".
3rd gen money
Oct 11, 2019 09:57 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Gunner242
Dec 25, 2015 04:49 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Damon
Sep 26, 2015 04:29 PM
