What problems are you/have you had with your thirdgen?
Just curious as to how many things mechanical, you've fixed, needs fixing. What common things(besides wearable parts like spark plugs and filters) are giving us the most problems? I've had my car a little over a month, and so far
Fixed
1.replaced passenger window motor(stuck down)
needs fixing
2.cracked trans mount
3.ac needed charging
Needs fixing
1.drivers window motor is on it's way out
2.smoke at startup-valve stem seals
other than that, mechanically's been great.I'm sure alot of you have had the same problems, along with headlight motors on Firebirds, and bad MAS's on TPI's. What does your list look like?
Fixed
needs fixing
Needs fixing
Car: 1992 Camaro RS
Axle/Gears: Stock
So far everything I've had to replace is the kind of stuff that wears out over 14 years. I still need:
1) door hinges
2) suspension (way too many squeaks and clunks)
3) head gasket
4) rear main seal
That's about it. She's still runnin strong though.
1) door hinges
3) head gasket
4) rear main seal
the only thing i have found a problem with just 3rd gens as opposed to any other car 20 years old is the transmission mounts...although hoefully ill take care of that when i get spohns tq arm.
I think I've replaced every part of mine that moves, at least once; and some things that don't move besides. And some of those, more than once.
No I take that back.... I believe the gas pedal might still be the original.
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
my a/c cuz its hot in florida and i need 2 rebuild my lil 305 carb cuz its shot,and my tranny slips like crazy, thats about it
Car: 88 Iroc-z
Engine: 350 TPI 5.7
Axle/Gears: Think its 2.77, posi
Car : 88 Iroc-z
Fixed :
1) Intake leak...gasket obliterated
2) Trans mount ... was nonexistent
3) Rear sway bar link ends ... equally nonexistent
4) Speedometer Cable ... cracked and worn but boy was I glad when I found out this was the problem...quick 20 bucks and half an hour well spent
5) Headlight switch ... connector melted
6) Gauge cluster ... the thin plastic sheet on the back was damaged and all the gauges had been spliced into to make room for what I'm assuming was just seperate gauges
7) alternator clip ... the plastic retainer that houses the three wires snapped...pretty common
8) Drag link and idler arm ... worn out
9) Hood shocks... dampners (sp?) worn
Need to Fix :
1) Timing chain stretched out
2) Need to find a way to get the idle down
3) Gearbox as there is too much play in the steering wheel...that stuff needs to be tight!
4) Gas and brake pedal ... when I got the vehicle it had those bizarre lights that flash and dance when you turn on the ignition.
5) AC needs to be either converted, removed or charged
I got this car about three months ago and I've run into problem after problem... but its all been fun and when I finally got the car up and running close to right it was all worth it. Turned out to be a timing issue...
Fixed :
Need to Fix :
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Lots.
Plastic radiator tanks crack. Several times.
Electric antenna takes a crap.
Alternator takes a crap. Like 3 times now.
Recharge aircon twice. R12 is expensive.
Clutch
Brakes
Water pump
Fuel pump
Temp sensors died (fans would not turn on)
MAF burnoff relay dies. Like 5 times now.
Distributor bearings failed. Shaft started to wobble.
Ignition module failed.
Computer failed twice
EGR valve
Speedo cable
Posi is no longer posi
Needs a new headliner
Needs steering column tilt bolts tightened
Tie rod ends
Had severe bearing knock starting at about 25k miles on the clock - new short block courtesy of GM. Replacement has been solid.
Is that enough?
Clutch
Brakes
Water pump
Fuel pump
EGR valve
Speedo cable
Tie rod ends
Is that enough?
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
replaced:
ball joints
fuel pumps
shocks
trans mount
motor mounts
swaybars
IAC valve
A/C compressor
radiator
needs fixing:
lifters(noisy, 190k mile on motor)
probably all the internal components(camshaft, main/cam/rod bearings and all gaskets)
timing chain
front brake(unknown clunk noise)
EGR
front end
differential(squeeks in curves, tire slip)
ball joints
fuel pumps
shocks
trans mount
motor mounts
swaybars
IAC valve
A/C compressor
radiator
needs fixing:
timing chain
EGR
front end
Car: 1982 Pontiac Trans Am (Recaro)
Engine: 5.0 v8 (305 TBI)
When i bought my car and was told everythin has been done by a American Car Dealer in the UK and £1000's spent over the years, which i soon to find out was £1000's spent on glue!! These things i fixed was done in one week kept finding more things broken/glued
FIXED:
Passanger and drivers side window motors
Passanger and drivers side locks
Passanger and drivers side lock solinoids
Passanger and drivers side window seals
Front springs
Brake disks and Pads
Alternator
Radiator
Valve Covers
Welding to back arch
T-TOP seals
Temp Sensor
Thermostat
Digital Temp Guage
Remote start (i know it doesnt count but its great when the car works
NEEDS TO BE FIXED:
Engine and tranny rebuild (worked ok until a jinxed friend got in and it back fired then lots of oil came out from head gasket)
door hinges
windscreen (hairline crack)
FIXED:
Front springs
Alternator
Radiator
Valve Covers
T-TOP seals
Temp Sensor
Thermostat
Digital Temp Guage
)NEEDS TO BE FIXED:
door hinges
BlackphantomZ28
Apr 24, 2016 08:14 AM
