cracks 10 sec before start then fine
Old Jun 30, 2006 | 09:37 PM
graphicideas1's Avatar
in the morning my car cranks 10 seconds before start then is fine until i let it set for a few hours. This started since i change fuel filter, but i see no leaks.
Old Jul 3, 2006 | 01:56 PM
Vader's Avatar
What year/model/engine?
Old Jul 3, 2006 | 08:20 PM
88 t/a 350 tpi
Old Jul 3, 2006 | 09:36 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
f/p relay? Sounds like it's waiting to build oil pressure before the pump gets power.
Old Jul 3, 2006 | 09:49 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
If RedDevil isn't spot on you might want to check the voltage. Battery could be draining somehow then it stays charged for a couple hours after the alt gives it a small charge.
Does it crank slow or crank normal but just longer?
Old Jul 3, 2006 | 11:19 PM
Cranks normal
Old Jul 4, 2006 | 12:58 AM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Check the cold start injector or the cold start sensor? May be worth lookin at.
Old Jul 4, 2006 | 06:41 AM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
I've had this problem with an old TBI camaro I once had. I needed to press the gas pedal for it to take less than 10 seconds to start. Turns out I had leaky injectors and pressing the pedal put the vehicle in 'clear flood' mode which is something like 20:1 A/F ratio. If pressing the throttle pedal when cranking helps your situation then I would look at your injectors.
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
