Key Stuck in Ignition Position
Old Jul 2, 2006 | 09:35 PM
Who Needs 8's Avatar
Hey, I have an 89 Turbo Trans Am. So I drove the car to do a couple of errands today. Got home, put it in the garage, and the key wouldn't move back. It will move to start (Grinding the starter ), but I couldn't cut the car off.
So I pulled the ignition fuse to get it to stop running, and I pulled the ground on the battery to save it.
So does anyone have any ideas?
Thanks in advance.
BTW: It does have the VATS key (Electronic Chip).
Old Jul 2, 2006 | 09:52 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
only thing i can think of is the gearshift lever is not fully in park, floating halfway between park and reverse, this would prevent the key from turning back to off.
Old Jul 2, 2006 | 09:59 PM
Yeah, I moved it around. It should also shut off in neutral, shouldn't it?
Hopefully it's not what ever connects the gear shift to the key lock.
Old Jul 2, 2006 | 10:04 PM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
I had this happen on my 89 IROC. I had to buy a new ignition switch and key set. I even called some locksmiths to see if they could unjamb it and they said it can't be done. Take the other key to a GM dealership, they will read it, and get you the right vats value. Parts stores will sell you one with an ugly key and a vats bypass for about the same money. The column is pretty tough and you need a few specialty tools. I would keep the vats, the new wire can be run with a coat hanger or equivalent.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
corey8084
Sep 17, 2015 02:56 PM
383cam
Sep 9, 2015 06:01 AM
