New Magnaflow Cat and my mileage went down???
Car: 91 RS
Engine: 350 TBI
The HP and TQ numbers in the sig were done with a tune on a dyno and a wide band O2. Shortly after that, I had emissions . . . that I promptly failed. Turns out the Carsound Cat was clogged or broke, or whatever it is when the cat fails to do its job. So I purchase a Magnaflow Cat (stepping up I thought) for it. I pass emissions, but my mileage seems to have dropped 1.5-2 mpg and the power doesn't seem to be there (atleast from my butt dyno).
Is it possible that I leaned out the mixture too much by putting a fresh cat on it? Before, as with most TBI's, we had it a tad on the rich side all the way through, but according to my Stewart Warner A/F ratio gauge (yeah, I know they're not the most accurate thing in the world) I'm hanging out in the stoich area alot.
I didn't think a new cat would effect it that much. Ideas? Comments? Suggestions?
Thanks boys.
Thanks boys.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Better get it checked right away....sounds over rich and will cook the cat in no time.
Most likely why the other one was bad
Car: 91 RS
Engine: 350 TBI
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
You asked if you were running lean? How would this make your mileage go to crap? This is definately an oxy sensor issue.... you have recieved no light?
Car: 1983 G20 Chevy
Transmission: 4L60
I am willing to bet that your O2 sensor got FRIED when the cat was welded into place. I have seen it more times than you would imagine. If the welder gets grounded to say the chassis and you strike up an arc with the pipe, hundreds of amps go towards the path of least resistance. That may just be the ECM and O2 sensor. The end result is the 02 sensor is damaged.
Car: 91 RS
Engine: 350 TBI
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Originally Posted by R4][N_M4l{3R
Just Gut it, do you really need a cat?
As he said in the first post he couldnt pass emissions, thats why he changed it in the first place!
Car: 1986 Chevrolet Camaro Z28
Engine: 383 Stroker
Axle/Gears: 7 1/2 Inch 3.23
Originally Posted by 84z28350
Obviously...
Car: 91 RS
Engine: 350 TBI
But what I meant to ask was is he dead set on passing emissions or can he just really not get around it?
And by stoich, actually at idle it hovers on the lean side of stoich, being especially on the border at idle when cold. I think I'm going to bump up the fuel pressure 1 psi at idle and see if that helps . . . I would rather buy a new cat than a new motor.
I'm just really suprised that going from a sh*tty clogged cat, to a really good new cat would cause this much of a change in the tune.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
where would the electricy go?
up the wire of the O2 into the ECU then out the through the ground on the ECU?
Car: GTA
Engine: 383 HSR
It could be a fault O2 sensor but I doubt due to welding. Those sensors take a beating from heat everytime you turn the key. I am sure you will get this worked out dude. One other idea I have, not saying its a great one... disconnect your battery for 10 minutes and then connect it. Let your ecm relearn everything, that way it can adjust for your new modification.
Car: 1983 G20 Chevy
Transmission: 4L60
Yes, it goes through the ECM.
Sounds like it is working OK though as he has his A/F ratio gauge still working.
Car: GTA
Engine: 383 HSR
I am still betting that when he disconnects the battery for 10 mins he will be golden... when i built imports, there was this guys honda, every time you do a mod you have to reset the ECU. His computer would not recognize the modification unless you reset the ECU, then when he would everything would sync up. i am not saying thats the case, but whats 10 minutes of your time?
Car: 91 RS
Engine: 350 TBI
Won't disconnecting the battery also clear out all of the old SES codes as well?
I did turn up the fuel pressure by 1 psi and it seems to run alot smoother.
LT1Formula
Oct 8, 2015 08:34 PM
