Engine Break in
Old Jul 8, 2006 | 12:18 AM
Iroc Adio's Avatar
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
Engine Break in
I just started breaking in my new motor. It has a flt tappet cam. I know i have to run it at 2000rpm for 20 min. I have about 6 min done already. I have to keep shuting the motor down because the headers turn cherry red and i didnt know why. Could anyone help me out? Thanks a lot.
Old Jul 8, 2006 | 12:33 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Probably retarded ignition timing.
Old Jul 8, 2006 | 03:34 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
while you've got it set to run at 2000RPM, try setting your timing to 24* or so.
Old Jul 8, 2006 | 02:24 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
Either your timing is off or your jetting is off. As long as you don't let it idle, having to break in the cam in a few shorter sessions isn't really that big a problem.
Whats your water temp when the exhaust is that hot? It probably doesnt matter that much, but red headers don't always mean the motor is actually to warm.
Old Jul 10, 2006 | 12:04 AM
Iroc Adio's Avatar
Car: 1987 IROC
I think i will try that. When i time it to 24* at 2000rpm should i have the vac advance blocked or flowing? Also when you time for total timing do you have to do the same? Thanks
Old Jul 10, 2006 | 09:58 AM
Sonix's Avatar
Car: 1982 Trans-Am
vac advance disconnected, both at 2000RPM, and for your WOT timing.
Old Jul 10, 2006 | 08:42 PM
Iroc Adio's Avatar
Car: 1987 IROC
I think it could be my jets. I have 74 primary and 75 secondary. How many jet sizes should i go up?
Old Jul 11, 2006 | 01:58 PM
Iroc Adio's Avatar
Car: 1987 IROC
I tried setting the timing at 24* 2000rpm the header still turned red. Its only #3 a lil bit but #5 and #7 get real red.
Old Jul 11, 2006 | 04:10 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
Pull the spark plugs and check them. If they are really fouled out then they won't be burning the A/F mixture and you are dumping raw unburned fuel into the exhaust and doing some damage to the exhaust valve.
Also DOUBLE CHECK YOUR FIRING ORDER!!! I had a similar problem when I broke my engine in, I mixed the 5 and 7 plugs because they are next to each other.
But good luck either way!!
Old Jul 11, 2006 | 04:18 PM
Iroc Adio's Avatar
Car: 1987 IROC
The 5 and 7 and ok i always double check those. the plugs are fine. i guess there isnt anything you can really do about the red header. im gonna bring the engine to 1500rpm and see how it works.
Old Jul 16, 2006 | 01:47 AM
Iroc Adio's Avatar
Car: 1987 IROC
I added timing to the ignition and the red glowing went away. I finished the 20 min break. I know I have to seat the pistons while driving it. Arent you supposed to acellerate up to 5000 in 2nd gear and then back off and let it lug down? Also when checking plugs how long will it take before i could get a good reading?
Wylecoyote08
Nov 6, 2015 03:46 PM
MY87LT
Aug 17, 2015 08:43 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
