Stupid question, loose dip stick?
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
The dip stick tube on my 350 is really loose. It basically just flops around, I can grab the "engine oil" handle and move it left-right all over the place. Is this normal for SBC?
Transmission: 4L80E/4L80E
"Normal" is for the dipstick tube to have a tab on it that bolts to one of the exhaust manifold bolts. Having no exhaust manifold bolts now myself, since I have headers, the simplest solution was to nylon tie-wrap it to things that pass by it (heater hose, for instance). It's probably something that deserves a more sophisticated solution, but I haven't found the motivation to execute it to this point.
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
If you can pull the whole tube out *including the dipstick* you will see a bulge in the tube, take some high temp rtv, and smear it around that bump. That will seal it and should help stop the movement.
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Whoever swapped in my 350 must have left that part off when they re-assembled the exhaust. I guess next time i'm under there i'll take a look at it, I just wanted to make sure the thing isnt going to fall off and spill oil all over.
