New engine leaking oil
Old Jul 8, 2006 | 06:17 PM
rsmaro90's Avatar
I go to start the new engine today and after 2 minutes at 2000 rpms to break in the cam oil starts leaking out of the oil pan right under the timing cover. I'm using the old oil pan but I flattened out the edges before I put it on. I ran a search and read up on the debate between using a sealent on gaskets or leaving them dry. Right now I'm using a cork gasket with rtv. Could this be the problem? Do you think I should get a one piece rubber gasket and just try that, or while I'm at it bite the bullet and get a new pan? Thanks
Old Jul 8, 2006 | 07:02 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Ehh kinda hard to say without seeing it.... Did you put big ole beads of RTV at the corners by the mains? That's always a common leak point
Old Jul 8, 2006 | 07:21 PM
rsmaro90's Avatar
Yeah I put a big dab in the corner but the pan was such a pita to put on that the rtv might have set up before the pan was completly torqued down.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
