Threads are DONE!
Old Jul 8, 2006 | 11:30 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Threads are DONE!
Well I got oil pan to line up and all finally and I got all of the bolts in and screwed down some, then I got to the driverside rear bolt which is bigger than the middle ones. I replaced the stud that was there with an ARP bolt and it screwed in easy, but it never stopped spinning, so I eventually said OH NO and when I pulled the bolt out, metal shavings were wrapped perfectly around the bolt. Now that means my threads are basically gone. I know I have to get a tap set or threadchasers, but what size should I get to fix it, or would it be easier to make the threads bigger and get a bigger width bolt? Thank you guys I am about fed up with this oil deal.
Old Jul 8, 2006 | 11:34 PM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
Axle/Gears: 10bolt 3.23's I think
go with the next larger size bolt / tap and you shouldn't have any problems.. may need to drill out the oil pan slightly. the other option is to put in a helicoil to end up with the same size as original.
Old Jul 8, 2006 | 11:40 PM
Engine: LB9, LB9
So a threadchaser would not more than likely fix the threads? I am sure they are probably too bad now I guess.
Old Jul 8, 2006 | 11:46 PM
Engine: LB9, LB9
Metric or Standard?
Old Jul 8, 2006 | 11:54 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
these are yugos... use a helicoil... they are insane strong and easy to use, plus you can use the stock bolt instead of jerry rigging a bigger bolt.
Old Jul 9, 2006 | 12:15 AM
Engine: LB9, LB9
How do you use a helicoil and where do you get them?
Old Jul 9, 2006 | 10:49 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
call up your parts store and tell them you want a helicoil kit for the thread size of.... whatever.
It's a helical threaded insert. You drill out your current threads, use their specific tap, tap for the helicoil, thread it in, usually using loctite or something. Then you now have your original thread size back.
Old Jul 9, 2006 | 04:54 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
The front two and rear two bolts are 5/16"
All of the others are 1/4"
Given that information,sounds like you need a 5/16" heli-coil set.It's money well spent,as it's something you'll likely use again.I keep every size from 1/4" to 1/2" on hand.
Old Jul 10, 2006 | 05:35 PM
Engine: LB9, LB9
is this easy to do?
Old Jul 10, 2006 | 06:02 PM
Irockz's Avatar
Probably not on your back under the car,but I don't see a lot of other options for you.
Pac J
May 17, 2020 10:44 AM
Elephantismo
Feb 13, 2019 12:51 AM
355tpipickup
Sep 28, 2015 05:50 PM
Linson
Sep 21, 2015 01:08 PM
