What did I Screw up?/Maro wont start!!
Old Jul 10, 2006 | 05:49 AM
iroc240_3's Avatar
89 iroc 350 tpi ...
Ive been having ideling issues so I decide to pull off the maf burn off relay while the car was running. I took my multi meter out and touch 2 pins to see if there was voltage, wasn't sure if there was suppose to be or not...
Anyways in the process of doing so I shorted something out causing the engine to quite on the spot. I tried to crank with no luck of starting. I waited about an hour and tried again with no luck?
I checked all the fuses under the drivers dash and none were blown. I heard there is an inline fuse somewhere in the engine bay...Could I have blown this?
Any help would greatly be appreciated....
Old Jul 10, 2006 | 06:11 AM
frogy's Avatar
Car: lowered 89 RS ttop centerline
Engine: 305 roller
Transmission: man uuuu el
Axle/Gears: stocking stuffers
supprised she ran w/o airflow sensor hoocked up.=unplug bat + reset ecm
could be the fuse ebay? questionable.big sparks,multimeter does not short **** out very easy,unless tips touch and bypass multimeter all together, creating a direct short at prongs connecting(arching),then would be the fusable.
this just an educated guess
Old Jul 10, 2006 | 06:26 AM
iroc240_3's Avatar
That's exactely what i did..There were sparks, I knew I shorted something out but what. I'll try resetting the ecm when I get home from work.
Thank
Old Jul 10, 2006 | 07:45 AM
blackroc68's Avatar
Do you mean the maf power relay? or fuel pump relay. check th e fuel pump fuse/. When you get it running set minimum air ,iac,tps
Old Jul 10, 2006 | 03:50 PM
iroc240_3's Avatar
Wheres the fuse located
Old Jul 10, 2006 | 04:33 PM
frogy's Avatar
Engine: 305 roller
check all fusable links by battery/right side of radiator mount
first get the meter (test light)back out and see if you recieving power.ground black to the car,most meters set to 20v,turn on power and probe harnes and see what does and does not light up,follow up the main wires and see if you still have power maf.if not checkin inline fuses and links
Old Jul 10, 2006 | 07:21 PM
iroc240_3's Avatar
Thanks for the info...
Car will crank just fine, just wont turn over!!!
Where are and how many inline fuses. I'm pretty sure that i smoked one. It was running until I arc faulted it to ground, game over after that
Old Jul 10, 2006 | 08:35 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
they are locate just off the positive battery terminal, and i beliveve there are 2, dont quote me, but there are atleast 2 right off the terminal (that I know for sure)
good luck!!
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
TheJoeY88
Aug 13, 2015 06:51 PM
blacksunshine'91
Aug 10, 2015 12:04 AM
