crank shaft bolt
Car: 82 camaro berlinetta/87 sport coupe
Engine: 87 LG4 305
Transmission: world 5speed
crank shaft bolt
hey i need to know what size bold i have on my crank pulley. all my tools got stolen and i trying to rebuild this 82 LG4 camaro motor i found. can someone help.
Engine: 87 LG4 305
Originally Posted by nelapse
You asking for the crank pulley bolts or the harmonic balancer bolt?
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Then yeah, sofakingdom nailed it right on the head then... 7/16" 20 thread 5/8" hex head. Can be found brandnew in a kit with washer and spacer also grade 8 for $7 at autozone.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
As a little precaution, buy a bolt that will bottom out or nearly bottom out in the crankshaft. The bolts that you buy usually barely start to grab when you are tightening them. Trust me, I have stripped out a crank bolt before.
Transmission: 4L80E/4L80E
You don't use the damper bolt to install the damper. You use a damper installation tool to install the damper. Then you remove the tool and install the retaining bolt.
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Ditto, Spend the money on a nice ARP unit with a ton of thread which will thread into the snout a good distance.
Car: GTA
Engine: 383 HSR
It's funny we are going off on a tangent about installing a harmonic balancer bolt but he only wanted to know the size.... micro management at it's best
ambainb
Apr 25, 2016 09:21 PM
gixxer92
Sep 1, 2015 04:32 PM
