FUEL ISSUES
Old Jul 30, 2006 | 12:03 PM
Azguy81's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 305 TBI
Transmission: Stock
FUEL ISSUES
Hello,
I am writing because my car has been out of commission for a while now and I finally have the $$ to get it fixed now the problem that I am having is that the car has been run once a week for the past 2 years just to keep the battery charged and to keep the engine from getting messed up but now I made a stupid mistake - I have been very busy at work and I asked a family member to start the car for me and allow it to run for 5 minutes but the bone head let the car run out of gas - I have added gas to it - roughly 7 gallons but I can not get the car to start - Any help with this issue would be greatly appreciated -
Here are the cars specs:
92 Chevy RS Camaro 305 TBI V8
Everything except the exhaust is stock
Old Jul 30, 2006 | 12:23 PM
92HeritageT~Top's Avatar
Car: 92 Heritage T-Top
Transmission: 5-Speed
Maybe try replacing your fuel filter and give it another shot. When it ran dry maybe it picked up some crud in the bottom of the tank?
Old Jul 30, 2006 | 12:27 PM
Azguy81's Avatar
Engine: 305 TBI
Transmission: Stock
More fuel
Does anyone think I may just need to add more fuel
Old Jul 30, 2006 | 12:30 PM
Just Bill's Avatar
nope.....
Old Jul 30, 2006 | 12:33 PM
cadman277's Avatar
Car: 95 z28,86 iroc
Engine: 350 lt1,305 tpi
The 7 gallons that you put in the tank is plenty.Do you have fuel pressure?I would start by checking this with a fuel pressure gauge.
Old Jul 30, 2006 | 12:46 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I too would start here. You can rent a fule pressure tester and if you have anything below 10psi you will need a new pump (assuming that a TBI pump is already present).
I would also change the fuel filter as mentioned above. Any sludge/funk that may be present on the bottom of your tank will be picked up with the last bit of fuel and may have clogged the filter. If you have an old fuel pump than running it dry may have been the straw that broke the camels back. Fuel pumps can over heat when the tank is run dry and if your pump was old it may have given up the ghost.
Old Jul 30, 2006 | 01:06 PM
Just Bill's Avatar
Being an OLD shade tree mechanic that I am.... and not knowing that much of the computer junk in cars these day.... I would shoot the intake with Ether (starting fluid) and see if it runs.... but again.... thats an old test.....
Old Jul 30, 2006 | 01:16 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It is still a good idea. You can determine right away if you have a fuel problem.
Old Jul 30, 2006 | 01:35 PM
Azguy81's Avatar
Engine: 305 TBI
Transmission: Stock
Running -
I had the car running for a minute after putting a bit of fuel carb but it only ran long enough to burn off that fuel
Old Jul 30, 2006 | 01:45 PM
Just Bill's Avatar
Did you check your fuses??? Also check to see if you can hear your fuel pump.... Sounds like your having the same problem I am having and I am getting ready to pull the fuel tank and see why the fuel pump isnt pumping...
Old Jul 30, 2006 | 02:56 PM
83Chevy_Camaro's Avatar
Car: 1988 Camaro
Engine: 1988 chevy pickup 350 TBI (rebuilt)
Transmission: 700r4- Bowtie overdrives
Axle/Gears: 2:73's
turn your key on and off a few times listening to the pump build pressure... Ive replaced my fuel filter twice in one year. and have drained the fuel lines like 4 times, Just tell us if you can hear the fuel pump kick on..
Old Aug 4, 2006 | 02:16 PM
Azguy81's Avatar
Engine: 305 TBI
Transmission: Stock
Fuel Issues
Ok after shooting the intake with starting fluid the engine kiks on for a few seconds but after the starting fluid burns off the engine stops.
I am thinking it may be a clogged fuel filter.
Does anyone have a diagram for where the fuel filter is? I know it is under the back end near the driver side but want a more exact for this car so I dont waste any extra time searching
Old Aug 4, 2006 | 02:28 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Look under the car in front of the drivers side tire, it's kind of hard to miss the filter.
Old Aug 5, 2006 | 03:35 PM
Car: 1988 Camaro
Axle/Gears: 2:73's
the filter is behind the rear driver passenger seat.. under the car of course.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
