fuel filter removal
Old Aug 3, 2006 | 08:45 PM
MiZZiE's Avatar
Car: '88 camaro/ '89 gmc s15 lower'd.
Engine: 305tbi 5.0 & 4.3v6 soon to be 350.
Transmission: 5spd manual/camaro.. auto/s15
fuel filter removal
i did a search with no results, i know theres a billion fuel filter threads so my mistake if this have been asked/answered recently is there any special kind of wrench or tool i can get to remove the fuel filter off my 88 camaro without twisting the fuel line? it's on there pretty good, i used PB blaster as suggested on the site but i don't want to strip anything. what is the best way to remove the fuel filter without twisting fuel lines ? and if not, what is the exact wrench size needed to un do i don't want to strip them.is there any special method of removing it safely?
also the reason i'm removing my filter is because its clogged, i know the trick to disconnect the fuel pump relay and run the engine till it dies, but this is not possible in my situation, so am i just going to have to deal with the gas spraying everywhere?
thanks,
Mike
Old Aug 3, 2006 | 09:06 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
The nuts on the ends of the line should spin freely on the line. I used a cressent wrench and it worked fine.
Old Aug 4, 2006 | 12:05 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
use 2 wrenches, line wrenches preferably. One to hold the filter, one to loosen the nut.
why can't you disco the fuel pump relay? theres other ways to go about that, pull the fuel pump fuse with motor running, and let it die...
or do you mean the motor isn't in running condition?
yea, I guess you can just enjoy the gush of fuel on you..
Old Aug 4, 2006 | 03:26 PM
MiZZiE's Avatar
thanks, line wrech was the words i was looking for. yea the reason i am changing the filter is because theres a fuel clog (motor runs beautiful) it's just it's not getting fed enough fuel to run, so i want to change/check if its the filter that clogged because i know my fuel pump is good.
will the gas keep coming or stop to a drip once the initial splurge of gas from the lines is empty? i know it works as a natural siphon so if i rig the line up at an angle after the first splurge of gas comes out or jack the nose up... will either of these help any? i just really don't feel like drinking any gas today LOL...
thanks,
Mike
Old Aug 4, 2006 | 04:34 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I was in a hurry and twisted my lines . Learned the hard way you can;t just patch it with a piece of rubber line . Way to much preasure. But man were they ever siezed.
Old Aug 4, 2006 | 05:16 PM
Sonix's Avatar
Car: 1982 Trans-Am
yea, the line on the tank side, tilt it upwards, or it'll just keep leaking until you tank is dry, and you'll be soaked... and when your friend lights up a smoke, you'll crap your pants in fear
so just keep the rear line up, and work quickly once it's off, you'll be fine. oh, and obviously don't smoke or anything dumb. Lay a lot of paper towel down too, and have a bucket to catch the mess too.
Old Aug 4, 2006 | 05:32 PM
MiZZiE's Avatar
haha thats what i was thinking, need to make sure theres nothing with flame or spark around me, it's hot enough out as it is, don't need no fire to keep warm LOL on a serious not thanks for the info everyone and hopefully i can get this sucker off without screwing up the fuel line (my biggest fear even though it can be replaced it's still an inconvience that would really put me in a bad mood LOL) thanks everyone this site is a big help as always. hopefully this is the main suspect in my fuel clog!
-Mike
Old Aug 4, 2006 | 07:23 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It'll help to remove the gas cap and take some pressure out of the system. I got an old old bath towel, and bunched it up under the filter, and held my head back as best as I could. It's not going to spew, just leak a trickle - but it'll seem like plenty at the time.
Old Aug 4, 2006 | 10:27 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Use two line wrenches. Soak the crap out of it with PB blaster, the connections on both sides and behind the nut on the line(s) and let it sit overnight. (If you are sureof yourself, take a punch and tap each line nut reall good once after you hit it lightly with the PB and then soak it)
It'll go much easier the next day.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
