What intake under stock hood?
Car: 92 RS
Engine: Built 355
Transmission: Built 700r4
Axle/Gears: 3.73's w/ stock axles
Ok guys....I am about to swap a 355 into my car. The engine was completely built with carb and intake manifold when I bought it. The problem is that it is a must for it to fit under the stock hood and I don't think that the victor jr that is currently on the engine will.
What would be a good intake that would fit under the stock hood and make good power with a carbed 355ci with aluminum heads producing about 375 horses with an additional shot of N2O?
Thanks in advance
Thanks in advance
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Thanks in advance
Thanks in advance
...and welcome to the club.
I can't even find out how much taller that intake is than stock.
I currently have the factory AL Q-jet manifold with stock air cleaner (from an '87) and it's clearance is about 3/8" to the hood.
It's here.
Let me know what you find out because I could use an answer also.
Car: 92 RS
Engine: Built 355
right now I have a 14x3 open air element, but I want to run a cold air intake off of the carb. I was just throwing this out there to see if someone would chime in on what they were running.
I say that the victor jr won't fit because it doesn't look like it will. If it fits I hope someone will chime in and correct me. If push comes to shove, I'll take both manifolds out and measure from the ground to the top of the intake.
And yes, I'm trying to create a super fast car that looks like stock and also retains a/c and all the other creature comforts.
Engine: 350 4BBL
...I say that the victor jr won't fit because it doesn't look like it will...
Victor Jr info.
You should find someone who runs at the strip and trade it. Like the spec says, it doesn't make much power below 3500 rpm and forget power brakes.
Car: 92 RS
Engine: Built 355
I will. My mechanic is building a thirdgen for his wife to drag at the strip. I'll try to unload it on him. Do you guys have any suggestions on what to run? I need power brakes!
Engine: 350 4BBL
.... I need power brakes!
Car: 92 RS
Engine: Built 355
HA Ha! I assume you're reffering to my thread "so I bought this engine." It's almost under control dude. I am going to swap the iron heads for 76cc aluminum heads, this gets me to 11:1 compression (according to jegs.) The cam is a .690 lift and happens to be for sale alog with the current heads, valve train, and maybe the intake if it doesn't fit.
I'm only in for $2000 and I have the nitrous, engine, carb, headers, ministarter and tranny. Not too bad huh?
Engine: 350 4BBL
Car: 92 RS
Engine: Built 355
I did get a good laugh out of it! The great thing about it is that with the advice of you guys this engine will be up and running soon with minor modifications. It's going to put about 375 hp to the ground and complete engine and tranny combo including the nitrous system (and full bottle) is only gonna cost me about 3500 bucks, and a buttload of headaches. But I work in steel structure fabrication, and if I got payed by the headache, I'ld be a millionaire!!!
Engine: 350 4BBL
Paydirt!!
Read this thread:
The answer to the air cleaner delima
This means we can use the RPM Air-gap manifold under a stock hood.
Read this thread:
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
haha, nicely done supervisor!
k, my few points to add:
-I run a performer RPM Q-jet, with q-jet, and stock single snorkle, new rubber motor mounts, and can close the hood without any "whack". No padding on underside of hood though.
-supervisor, those camaro wheels like really nice on the TA,
. Also, I remember hearing your dyno pull with that motor, sounds like a beast! What was the dyno result again? and what cam/heads, if I may?
-systalis, you work in steel structure fabrication? You're gonna fab up suspension bits then ? SFC's, wonderbar, LCA's, panhard,
give'r!
Engine: 350 4BBL
What we're talking about: Dyno Pull
Car: 92 RS
Engine: Built 355
I was thinking about fabbing my own parts sonix, but unfortunately, I am putting in about 70 hrs a week at work. It sucks but it allows me to have my hobby without having a divorce!!!
I got spohn sfc's, wonderbar, and umi's panhard. I am thinking about fabing a custom strut tower brace that connects to the firewall. After all those hours at work I don't really feel like cutting and welding though.
I know everything about framing drilling platforms, but nothing about automobiles. Sounds strange huh? One sounds alot more complicated than the other!
Car: 92 RS
Engine: Built 355
thanks supervisor! I read that thread twice. I'm not hell bent on useing the victor jr, but that's more money I can spend on getting this engine and proper exhaust in my car sooner. I can always change the victor jr later.
If I was buying a new one I wouldn't choose this one, But since I already have it!!
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
