i SMELL GAS.....
Old Aug 8, 2006 | 06:47 AM
RST89's Avatar
Car: 1983 camaro
Engine: 2.8...... 3.8t coming soon or should I do a ls6 almost the same cost hmmm.....
Transmission: 3spd soon to be either a 700 or t56....
i SMELL GAS.....
OK I HAVE a 83 2.8 3spd with 2bl electronic carb. i dont know what to do my car uses tons o gas it seems every now and then u get a good strong gas smell. also at start up there is white smoke and not to mention the deisiling off!!! i lowerd the idle on the car because it seemed high and it helped but the idle is so low it alsmost stalls so not a good fix on that the card is fresh so i dont know what is wrong PLEASE HELP THANKSYOU!!!!!
Old Aug 8, 2006 | 08:28 AM
Vader's Avatar
My guess is that it's time you learned something about the E2SE carburetor, and how to adjust one. There could be many problems, from float level, inlet need valve, idle air bleed adjutment, throttle position sensor adjustment, leaking bowl/well plugs, and others I'm probably forgetting.
Old Aug 8, 2006 | 02:38 PM
RST89's Avatar
Car: 1983 camaro
ok....
ok where do i start i am willing and eager to learn also i forgot to mention what seems like a fluxuation in idle while in drive... dont really noice it in n or p but iot may be because the idle is so low i dont notice it thanks for all the help in advance
Old Aug 8, 2006 | 03:08 PM
RST89's Avatar
Car: 1983 camaro
vader
hey in some looking around i found some of your post do u think my tps needs adjusting?? the carb was just rebuilt and made the car do near perfect this is now a new problem with the smoke bad mpg and fuel smell. thanks again ... which wires do i check for tps and what voltage should they be??? and my 02 should i check that??
Old Aug 9, 2006 | 10:40 PM
RST89's Avatar
Car: 1983 camaro
some one help
TTT
Twin_Turbo
Mar 14, 2016 10:10 PM
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
