How bad does this sound
Old Aug 8, 2006 | 09:19 AM
cohan305ci's Avatar
Car: 87 Z28
Engine: 305 ci TPI
its my engine as of yesterday (the thing blew on me, n i finally got it started again, but its not lookin good)
Putfile - My Broke Engine
its an 87 305 Z28, tpi
idk wether to restore it or go with an engine swap, im gonna hafta get a new transmission ne way, i only had the car for 4 days b4 it broke down on me
Old Aug 13, 2006 | 08:02 AM
Vader's Avatar
Any more detail? The site you linked doesn't work for me.
Old Aug 13, 2006 | 08:22 AM
calobs87irocz's Avatar
Car: 87 Iroc Z, 70 & 71 Camaros, 79 Z-28
Engine: 350TPI, 350, 355, 355
Transmission: 700R4, TH350, TH350, TH350
Axle/Gears: BW3.27, 4.10, 3.73, don't know yet
That sounds bad. With the video you can't tell where the noise is coming from, but there's definitely more noise than there should be . Have you checked all of the accessories?
As far as what to do, half of me is a numbers matching, everything correct type person. The other half is a "let's see how much power I can get" person. If that's the original engine, then I would look at a rebuild. You might tear it apart and find that it's just something that you would replace in a proper rebuild anyway. Not only would rebuilding the motor increase value down the road (most likely), it's also cheaper in most cases. The exception would be to find a decent long block. I've seen good running 305's for around $100.
Old Aug 13, 2006 | 03:13 PM
cohan305ci's Avatar
Car: 87 Z28
Engine: 305 ci TPI
pretty mnuch all i know is that it was running fine till it stalled out on me and smoke started flyin from the engine, n after that it makes taht noise, overheats n wont go past 2nd gear
knowing me, im most likely gonna go with a rebuild, but if i cud find a 5.7L angine ne time soon i might go with a swap as long as it comes with an auto tranny
Old Aug 13, 2006 | 07:54 PM
vortech35091RS's Avatar
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
Sounds like you have a flock of birds down there....I can't tell much by the sound. Hows your oil look, any metal shavings?
Old Aug 13, 2006 | 11:26 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Wow, sounds like the crank case is full of gravel.
Old Aug 14, 2006 | 01:58 PM
cohan305ci's Avatar
Car: 87 Z28
Engine: 305 ci TPI
idk, i checked the oil found nothing in there, besides fresh oil from wen i changed it 2 days b4 it broke, i might end up takein it to a shop real soon if i cant find the problem
Old Aug 14, 2006 | 04:59 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Sounds like time for a 350 upgrade.
Old Aug 14, 2006 | 11:47 PM
cohan305ci's Avatar
Car: 87 Z28
Engine: 305 ci TPI
yeh im lokin for one but cant find ne i cud really afford for now
xxx3man`
Sep 23, 2015 10:37 PM
TheTraut88
Sep 11, 2015 05:16 AM
Amillionoh7
Sep 5, 2015 11:44 PM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
