1984 2.8 running rich
Old Aug 21, 2006 | 07:44 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
Well the exhaust on my carbed 2.8 smells rich, is there anyway to solve this problem? I tried a higher octane, doesnt seem like you can adjust the car. It has the CCC computer in. Any ideas?
Old Aug 22, 2006 | 08:06 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
"Rich" on these cars is pretty common. Check your TPS voltage and MCS operation (do a search or the Haynes manual has a pretty good procedure). Make sure your choke is operating properly too.
BTW-changing the O2 sensor the last time this happened on my '84 made the "rich smell" go away.
Old Aug 22, 2006 | 01:11 PM
Car: 84' Trans Am
would the oxygen sensor cause bad mpg's? If im lucky i get 12mpg aver. Also i was going to try to pull some codes and see if that works.
Old Aug 22, 2006 | 01:26 PM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
If you're running rich all the time, yes you'll get terrible mileage, although the carbed 2.8 never got good mileage to begin with. My '84 when new was lucky to get 15-17 mpg in city/highway driving.
Old Aug 22, 2006 | 03:32 PM
Car: 84' Trans Am
Yeah, it always has a strong odor from the exhaust, then when you seem to give it the gas it tends to bog out a bit and kicks in. Im willing to bet it has alot to do with the 02 sensor. Do you know if these are hard to replace?
Old Aug 22, 2006 | 03:40 PM
Car: 84' Trans Am
Is that with the overdrive transmission?
Old Aug 22, 2006 | 03:50 PM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
Yes it's an OD tranny (I think all '84s were). The O2 sensor can be a royal PITA to get out if it's never been changed or has been several years. You'll need an O2 sensor socket or a good open end wrench and a can of PB Blaster. Spray the sensor threads and let soak for several minutes. You may have to do this two or three times before the old sensor will break loose.
Old Aug 22, 2006 | 03:57 PM
Car: 84' Trans Am
Haha great, sounds like fun. It probaly has never been done so that is great. It must need it though cause the exhaust smell rich even when your in the car.
Old Aug 22, 2006 | 04:02 PM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
Clean up your choke and all the carb linkages while your at it and make sure to check the throttle position sensor. The bogging you describe happens on my '84 when the choke is sticking but can happen also if the TPS isn't adjusted right.
Old Aug 22, 2006 | 04:05 PM
Car: 84' Trans Am
Where would the tps be, it only does the bogging during wot.
Old Aug 22, 2006 | 04:09 PM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
WOT with a 2.8 carb? You must really want an excuse to put the V8 in sooner than later
The TPS is on the front of the carb (driver's side) and has three wires running into the connector.
Old Aug 22, 2006 | 04:17 PM
Car: 84' Trans Am
Haha, had to merge on a freeway with it, ill have to check that tps, i thought only fuel inj. motors had those. I noticed when i bought the car that the smog pump pully(the thing under the alt.)was diconnected, would that have anything to do with the running rich?
Old Aug 22, 2006 | 04:28 PM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
If the carb is running rich all the smog pump will do is dilute the tailpipe gases and add air for the cat converter to do its thing. It's more of an emissions testing thing. There are plenty of TGO members that have physically removed the air pump and the cat from their cars and still pass emissions. In short the air pump may help get rid of the "rich smell" but has nothing to do with the carb running rich in the first place.
Old Aug 22, 2006 | 04:33 PM
Car: 84' Trans Am
Well im going to replace the o2 for sure, then look into the tps. I dont know if its common for these car but of and on the car will smoke alittle out of the tail pipe, i was told also this could be cause of the o2 sensor, its a grey colored smoke.
Old Aug 25, 2006 | 11:47 PM
Car: 84' Trans Am
Well after reading in my haynes manual it says you need to torque the new sensor, can you get away with just snugging it on there good?
Old Aug 26, 2006 | 09:22 AM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
Yes but make sure you put some anti-sieze on the threads and don't "snug it" too tight, maybe just a 1/4 turn after you feel good resistance.
Old Aug 26, 2006 | 10:56 AM
Car: 84' Trans Am
Cool, thanks
Old Aug 29, 2006 | 09:22 PM
Car: 84' Trans Am
Swaped the o2 sensor today, alot more power, havent hit the highway yet, but that rich smell has def. gone down.
Old Apr 17, 2007 | 09:46 AM
Car: 84' Trans Am
Re: 1984 2.8 running rich
Im having this problem again, but now if i go from a stop it will lope a little when easy on the gas, Almost like its bogging out. The carb was rebuilt before so that cant be it. Any ideas anybody. Btw the rich smell is back lol.
MustangBeater20
Oct 29, 2022 09:20 PM
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
