what exactly is a nickel block?
Car: 92 RS
Engine: Built 355
Transmission: Built 700r4
Axle/Gears: 3.73's w/ stock axles
Like the title says. What exactly is a "nickel block" and is it better than a standard block? What years were they made and for what applications?
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
I'm not very literate on the type and number of SBCs out there, but I believe you are referencing a certain type of casting that contained a higher nickel percentage than most typical blocks. "High Nickel" blocks are supposedly a better casting, and have more strength, but I'm basing that on hearsay, as I have no experience with them.
Car: 92 RS
Engine: Built 355
I'm building an engine with one that someone gave me and I was wondering if thats a good thing. He swears that it is and i was wondering what would be he benefit if any.
Thanks for the reply
Nothing wrong with free... wish I had one of those haha. Is it in good shape, or are you going to have it machined, etc.?
Would you mind posting the casting numbers on the block?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
there was a thread here a while ago dispelling the myth of the high nickel block. Search on it.
It's not a big deal either way.
it's just a run of the mill 350 chev, dont' get too excited about it... 'cept that it's free, that's always a plus.
Car: 92 RS
Engine: Built 355
Thanks sonix, I did a search with no results but I did it on "nickel block" I'll try "high nickel block" instead. You're always a help.
Quick trans am, No I would not mind posting the casting numbers on the block but its at my buddies shop and he's offshore for two weeks. I almost got them Sunday, but I forgot.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
All blocks have some nickle in them. Typically, you look for a casting number behind the timing cover. You should see a number 010 or 020. 010 means 1% nickel. 020 means 2% nickel.
Car: 92 RS
Engine: Built 355
I did a few more searches and I found it. Seems debatable as to how to determine if you have one and if there is any benefit at all. But thanks for all the info guys!
Car: 1982 Trans-Am
'zactly, you saw the thread with the guy who worked casting SBC blocks? So according to that guy, it's an urban legend.
Either way, I highly doubt the block is your weak link where you are now, so it's not really a big deal anyway.
Car: 92 RS
Engine: Built 355
yeah, I saw it and it seems funny because everyone says that the 010/020 under the timing chain is a dead giveaway. According to that guy, it means nothing. Guess you gotta believe the guy that makes the things huh?
Well anyway, it's a four bolt main, free, and going to be .030 over. And yes, i have read all about 4bolt vs. 2 bolt.
skinny z
Oct 5, 2015 06:23 PM
. That sounds like a good base with which to start.
