Tank or block?
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
Tank or block?
I thought I read somewhere that 82 third gens had the fuel pump mounted to the block. Is this true? My 4 banger has a pump on the block, but when I turn the key I can hear an electric pump. Is this a push-pull setup?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
mine was block mounted, but if you have the 4cyl with TBI injection I think it'll have both.
So when I finally do my engine swap to a carbed v-8, I'll have to choose between the two? I actually prefer a block mounted pump on a carbed motor, but I don't feel much like dropping the tank. Just one of those things I guess...
Car: 1982 Trans-Am
yea, i'd stick with the block mounted.
I think you can drop the tank and remove that pump, and just put a "normal" pickup in. It's hard to draw through a dead/not connected/whatever electric pump, and you can just do one or the other. (I'd lean towards the block one...)
Bohemian
Aug 15, 2017 05:11 PM
RyanJB
Sep 14, 2015 03:39 PM
