How to check/set timing on 91 rs 305
Hi again I want to check the timing on my camaro but i want to be sure that there are no leads or any connections that need jumped or anything. and my hood is from a v6 so what should it be set to? its a all stock 92 305 but i want to be sure its where it belongs. can some one please post me the instructions? thanks
1 Post
Car: 92 Z-28
Transmission: THM700R4
Insane, I'm not sure what you mean about your hood being from a V6, but setting the timing is very easy. Just connect timing light to battery, put the lead on the #1 cylinder, which is the first cylinder on the right side of the engine. Disconnect the timing lead on top of the passenger side wheel well, this location is also located in any Haynes or Chilton manual. Start the car up, point the gun at the pulley located at the bottom of your motor, make sure you can read the marks on it. there are prolly better directions on the site. Go to the engine thread. I'm fairly new at this but did this a number of times trying to diagnose what turned out to be a fuel pump issue. Happy timing.
the hood has a v6 sticker so i dont know what the base timing is supposed to be. You answered my question about a jumper so its on the passenger side firewall? my last hot rod had a mechanical HEI with the vac adv removed and was easy to check initial and "all in" on these cars i guess you only check initial after the jumper is unhooked and thats it?
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
The lead he is talking about is a brown wire that plugs into another brown wire. It is hanging out of the wire harness and is real easy to spot. Be sure to disconnect it or your timing will be WAY off. Me personally I run my 91RS with a 305 at 6* advanced. Be sure to re-time it after tightening the distributor, just to make sure you didnt accidentally bump it. Shut off the car then hook your brown wire back up then you should be good to go.
crap i messed up timing
Ok i think i screwed up i found this pic and it shows the timing tab, i was advancing my digital timing light to 6 degrees advance and then putting the notch on the first peak (see 4 degrees atdc) i thought that first tab was 0
So tommorow i guess i should recheck it.
for a 305 tbi it should be 0 not 6 advance?
can any one confirm this? my hood is off a v6 so i dont have the sticker. its a 91 rs 305 tbi where does my timing belong?
also could some one please tell me what this initial setting really does sinc ei thought the computer controled timing. thanks
I cant even find this out on google. lol does any one know for sure what this should be set to for this car?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If your TBI motor has swirl port heads (casting number 187 (305), 193 (350)) than the stock setting is 0°. I would not go above 4°. Swirl port heads are fast burn and do not need a lot of initial advance. Going too high will yield undesirable results.
As mentioned, to set the timing,
Unplug EST
Fire car
Set timing
Turn off car
Plug in EST
Grab beer because your done.
There are more detailed instructions located in the stickies at the top of the TBI forum.
Unplug EST
Fire car
Set timing
Turn off car
Plug in EST
amastrian (07-01-2023)
db057
08-11-2015 10:11 PM
