can i just change my lifters?
Old Aug 25, 2006 | 01:48 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
I read on my hayness manual, that if i replace my
lifters,
i "must" replace my cam at the same time.
but i dont have skills nor will to change my cam,
i just want to dump in a new set of lifter so my engine noise will reduce,
for now.
as of now i have a stock cam&lifters,
so considering mismatch of cam&lifters,
if i get a stock GM lifters from GM, for direct replacement,
will it be ok to replace lifters but not the cams?
thanks in advance!
Old Aug 25, 2006 | 01:53 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Is it a roller cam engine? If so, you can replace the lifters and still use the old cam, but here is probably no need to do that... Roller lifters usually last longer than the cam does. Maybe they need an adjustment?
Old Aug 25, 2006 | 02:02 AM
sogabe's Avatar
Engine: 3.1L
sorry forgot to mention..
my car is a 91 v6,
and I believe its a hydraulic lifters.
my car just past its 191k miles,
and never been replaced so
adjusting my valve might help,
but while im at it I want to just get a new lifters in.
is new lifter and old cam a no-no or something?
thanks in advance again.
Old Aug 25, 2006 | 02:44 AM
ede's Avatar
ede
why do you want to replace them? just because or do you know something's wrong with them? if they need replaced so does the cam.
Old Aug 25, 2006 | 02:54 AM
sogabe's Avatar
Engine: 3.1L
i have tapping kinda noise from my engine and its pretty loud.
i sort of pin pointed where my noise is coming from,
it comes from valve train and its probably the lifters, possibly the cam too.
every shop i go to, they tell me its probably my lifters too,
since they arent like ultra expensive and not crazy hard to do(unlike cam),
i wanna take my chance and change them.
but i do NOT wanna do cams, its just too much work and i have no time for now.
so im just wondering if ill have problem just changing my lifters.
i drive my car 60miles everyday, it runs just fine.
its just the noise is kinda loud and i just wanna fix it.
Old Aug 25, 2006 | 10:15 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think it's rockers more than likely.
If your lifters are screwed, there's a high chance your cam is as well, and the bandaid fix of putting in new lifters won't help you.
Hydraulic roller lifters is what you have, and I think they're kinda pricey actually...?
You can pull out your lifters and look at them, might find if they actually are the problem or not. I'd start with rockers, they're easier to get to and check, you'll know if there's a problem there.
Old Aug 25, 2006 | 04:16 PM
ede's Avatar
ede
if your lifters need replaced so does you cam, there's no way around it. i'd also bet your problem lies else where.
Old Aug 25, 2006 | 05:58 PM
Vader's Avatar
However, if the valve train noise is due to a lifter(s) leaking, stuck, or not adjusting due to being varnished, and the bottom wear face of the lifter is not worn, you can either clean the existing lifters or replace them. If you pull a lifter and it shows excessive wear on the bottom contact face, you're looking at a cam as well.
That said, I'm fairly confident your engine uses roller lifters, and you CAN replace those with no problems.
Old Aug 25, 2006 | 06:04 PM
sogabe's Avatar
Engine: 3.1L
do u mean the rocker arm went loose or something?
I was thinking that too, but if i disassemble that far,
i thought of changing lifters might as well since motor is at 190k mile
and lifters are worn.
my ONLY question is weather putting new lifters while keeping the old cam will
give me any problem.. thanks. I know it wont solve my whole problem,
but just trying to see if it'll make my noise better.
Old Aug 25, 2006 | 06:51 PM
Sonix's Avatar
Car: 1982 Trans-Am
well, take off the valve covers and inspect the valve train. I'm not familiar with the 3.1L, but valve covers shouldn't mean taking off the intake manifold, and getting to the lifters.
Once you inspect the rocker arms and pushrods, you might find your problem. My money is on that.
If nothing is found, remove the intake and check the lifters. If you find the bottoms of them worn, then it's cam and lifters time. New lifters will NOT help you there.
Old Aug 25, 2006 | 08:15 PM
Vader's Avatar
On the 3.1L V-6s, the intake is about half of the rocker cover. You should still be able to remove the covers alone and inspect the rockers.
Old Aug 26, 2006 | 12:55 AM
sogabe's Avatar
Engine: 3.1L
thank you! thats exactly what i wanted to know..
i will look into the rockers first then see what ill do with it.. thanks again
db057
Sep 4, 2015 07:57 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Brendankup
Aug 30, 2015 01:46 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Cameeeero
Aug 20, 2015 03:06 AM
