what are the chances i screwed up?
Old Sep 6, 2006 | 12:02 PM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
heres what happened, i pulled the motor out to put in my cam, figured while it was out i might as well put some new hyper slugs in it, had the crank ground, and balanced the rods/pistons. a friend was helping me put it all together, i put the cam in, then he lined up the cam and crank sprockets. and i think its one tooth off, when i try to turn the car over it wont fire, but backfires out the intake. so it seems like the exhaust valve is closed when it should be open.
my question is, what are the chances ive bent some valves? im guessing really good, but REALLY dont want to have to pull the motor again which is what it looks like i have to do
Old Sep 6, 2006 | 12:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are you sure you've got the distributor in correctly?
Old Sep 6, 2006 | 12:31 PM
sprojam's Avatar
Car: 86 Z-28
Engine: 355 small block XR276HR roller cam
Transmission: TCI built 700r4 2000 lockup stall
Axle/Gears: moser axels auburn posi 3:73 gears
i think you have a timeing issue i just have this problem on my motor distributor was off check your timing through out good luck
Old Sep 6, 2006 | 01:00 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
distributor may be 180 degrees out, it's happned to me before.
Old Sep 6, 2006 | 01:05 PM
sprojam's Avatar
Car: 86 Z-28
funny thing is it might not even be 180 out i got hung up on that mine was out about 60 its best to mark #1 on distrib housing an make sure it lines up to that at to dead center good luck the biggest part of this seems to be getting the damn oil pump shaft lined up extreme patience an make sure your firing order is corect
Old Sep 6, 2006 | 01:35 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Sounds like a timing issue to me. I say stay with the K.I.S.S principal lol (Keep.It.Simple.Stupid) 9 times out of 10 it is usually something minor that has been overlooked
Old Sep 6, 2006 | 10:25 PM
Car: 89 Formula
Engine: 5.7 TPI
but having the distributor in wrong wouldnt have anything to do with valves opening and closing. so i dont see how timing would be my issue as of yet.
Old Sep 6, 2006 | 10:32 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
it's probably firing the spark while your intake valve is open.
Old Sep 7, 2006 | 03:26 AM
ede's Avatar
ede
to answer your question about the bent valves. i'd say the chances are next to zero as long as your cam lift isn't over .6. you have the distributor in wrong, either move it or pull it and reinstall it.
3rd gen money
Oct 11, 2019 09:57 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
LT1Formula
Oct 8, 2015 08:34 PM
armybyrd
Sep 26, 2015 03:37 PM
