HELP Car wont start???
Old Sep 16, 2006 | 05:05 PM
phoenix64's Avatar
I just bought this 92 305 5-speed rs, I think I got screwed. Took it for its first drive, radiator started leaking. Just a few hours ago I got done relpacing the radiator, started it up, let it warm up, and took it for a drive. It made it about 2 miles before it quit completly. The tach stopped working early on, and then the engine died, and there is no response on the dash when you turn the key. No clicking fo the starter, or anything. The lights, and the hatch still work though?
Any help would be hugely appreciated.
Possible causes, I disconected the air system. The engine was exteemly hot, but the gauge showed 140*, Also I had the A/C on when it quit.
I don't think the fans work? they never came on at all.
Old Sep 16, 2006 | 06:29 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Still getting any kind of power? Battery dead? Maybe the alt crapped out and it was running on battery and shut down. Or common hot-shutdown cause is the ignition module, it overheats and stops working til it cools off.
Still no start even when it cooled down? Tried push-starting it?
Old Sep 16, 2006 | 06:38 PM
stevog66's Avatar
Car: 1984 F-41 Camaro Sport Coupe
Engine: LG4 V8
Axle/Gears: stock
battery terminals coroded? Mine were no clickwhen turn key but lights still came on,had to clean them with wire brush every other day until i finally put some baking soda on them and starts everytime now,check ignition module maybe??? could be a short in your wiring somewhere.
Old Sep 16, 2006 | 07:08 PM
phoenix64's Avatar
the headlights, and the rear hatch work, but I can't get anything at all out of turning the key. no dash lights, no click nothing.
Old Sep 17, 2006 | 01:57 PM
phoenix64's Avatar
help???? Anybody?
Old Sep 17, 2006 | 02:30 PM
sikZ28's Avatar
Car: 86 Trans Am
there should be a fusible link up by the battery, check it.
Old Sep 17, 2006 | 03:11 PM
phoenix64's Avatar
There is one by the battery on the fender, but its still good.
Old Sep 19, 2006 | 06:13 PM
phoenix64's Avatar
anybody??
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
