4 piece oil pan gasket + rtv
Old Sep 19, 2006 | 12:20 AM
350ChevyMania's Avatar
What would be the best way to put on a four peice gasket (2 cork + front/back rubber seals) with rtv?
Old Sep 19, 2006 | 12:43 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
purchase a one piece gasket from autozone and save all the headaches. or put the 4 piece one together and then RTV the corners
Old Sep 19, 2006 | 03:34 AM
ede's Avatar
ede
+1 on the one piece. if you're set on using the 4 piece gasket RTV the joints where the sides meet the ends. it'll just take a little spot of RTV to do it.
Old Sep 19, 2006 | 05:57 PM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
+eleventybillion on the one-piece. I've got less than 300 miles on my rebuilt engine, and it's got the 4 piece, and leaks BAD, even w/RTV and wirewheel-ing the old gasket off. I've got the one-piece sitting, waiting for this weekend.
Old Sep 19, 2006 | 06:02 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
what if you're running a moroso deep sump pan? i put the one piece on, and it leaked like hell from the front seal. put on the 4 pieace, still leaks, just not as bad. is my oil pump producing too high a pressure? or could mye timing cover just be a piece of shiz?
Old Sep 19, 2006 | 06:04 PM
BRobinson's Avatar
Car: 82 Camaro
Axle/Gears: 3.08
Or your balancer seal could be bad.
Old Sep 19, 2006 | 09:36 PM
xpndbl3's Avatar
Car: 1984 Z28
sounds like you got the wrong front lip for your one piece seal for the timing chain cover that you're using.
Old Sep 21, 2006 | 09:14 PM
Could you reccomend a good one piece gasket online? Needs to be a site with paypal. I'm not really sure what engine I have. It's a 350 but I couldn't tell you what vechicle it's from.
PS. I'm also in need of an intake gasket too. Just noticed the ****er was shot to hell and coolant on the intake. I have an Edelbrock performer intake.
(God I feel like such a noob)
Oh yeah, what would the rtv installation be like one a one piece?
MoJoe
Sep 24, 2015 09:12 PM
gixxer92
Sep 1, 2015 04:32 PM
downsouthboy
Aug 29, 2015 11:29 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
