Belt routing on a 91 w/o AIR and AC
Old Sep 21, 2006 | 09:02 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Can I remove that whole bracket on the passenger side and use a set up like this? What are you guys running?
Attached Thumbnails Belt routing on a 91 w/o AIR and AC-untitled.jpg
Old Sep 22, 2006 | 07:11 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
It would be nice to lose the whole passenger side bracket but you would need more contact on the water pump drum (no grooves) and keeping the belt tensioned without a spring would require constant attention. Serpentine belts don't have any "give" to them like V belts.
Maybe you could try something like this:
Attached Thumbnails Belt routing on a 91 w/o AIR and AC-belt-routing1.jpg
Old Sep 22, 2006 | 10:47 AM
Damon's Avatar
Somebody did this around here not too long ago, without using the A/C delete pulley. It worked and looked pretty trick, but I think he had to use a different tensioner pulley (ribbed to work on the other side of the belt than it normally does).
It's certainly no big deal just to get the A/C delete pulley, ditch the air pump and put on a 96.8" belt with the altered routing diagram shown in the tech article section of this board (how to delete your smog pump).
Old Dec 20, 2006 | 01:43 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
That first picture is exactly how I have my setup. No waterpump slipping, I'm using serp belts, but I did have to make a slider bracket on the alt to tension everything.
Looks very trick but next I'm moving the alt low on the pass side (to hide behind the CAI) and getting a new bracket for my PS pump.
Old Dec 20, 2006 | 03:24 PM
85s10tpi's Avatar
Car: 88 gta 305 tpi in a 85 S-10
Engine: 88 maf LB9 T.P.I.
Transmission: 700r auto st.2 kit
Axle/Gears: stock 3.44 s-10 diff
im in the mix of doing this on my s-10 with serpentine
im drilling a new hole for the tensioner so it pulls UP instead of down my a.c./a.i.r. bracket is modded to allow the alternator to be in place of the a.c. compressor i have a pic of it here:
Attached Thumbnails Belt routing on a 91 w/o AIR and AC-alt-crap.jpg
Old Dec 20, 2006 | 03:27 PM
85s10tpi's Avatar
theres also this picture he has his alt mounted where the a.i.r. pump was
Attached Thumbnails Belt routing on a 91 w/o AIR and AC-serpentine-suetup.jpg
Old Dec 21, 2006 | 01:10 AM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
that is how i had mine for years with no problems. All you have to do is make a bracket for the top altenator hole so you can adjust your belt. its real simple, and i actually used one of my engine hoist brackets that are bolted to the intake for the top altenator adjustment, i know its a little ghetto but poor people got poor ways, and it worked like a champ
Old May 19, 2007 | 11:12 PM
1989formula355's Avatar
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
Re: Belt routing on a 91 w/o AIR and AC
i'm trying this setup on my car. no ac, no smog, no tensioner. i rolled a 51&1/8" belt on the pulleys by turning the crank bolt. i'll let you know how (or if) it works. it's as tight as a belt should be so i'm not too worried, and the engine compartment looks pretty clean.
Old May 20, 2007 | 07:50 AM
crrllmich's Avatar
Engine: L03, LS1
Can you post a bigger pic?
Old May 20, 2007 | 11:47 AM
don't know how to. there's a better one at my vbgarage
Old May 20, 2007 | 01:58 PM
Engine: 350 4BBL
Quoting Darth Vader: "All too easy"
Old May 20, 2007 | 10:34 PM
Old Jun 14, 2007 | 09:00 PM
so far so good.no tensioner, no slipping yet. we'll see how long belts last.
Old Jan 9, 2009 | 05:33 PM
crrllmich's Avatar
Engine: L03, LS1
Sorry to bring this back but how did you guys make your alternators adjustable and still be rigid?
Old Jun 2, 2009 | 09:13 PM
5.0slayer's Avatar
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
any one got a part number on that 51 1\8" in belt that
1989formula355 used
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
