what just happened? did i blow a head gasket
Old Oct 1, 2006 | 12:25 AM
street_carnage's Avatar
Car: 89 GTA
Engine: 5.7L
car hasnt been started for 2 months. i forgot this even happened until ppl started talking about blowing head gaskets. I fired it up the other day. and let it idle. the choke was on so it idled at like 2000 rpm for a few minutes. ( i still have to adjust timing and carb) i had to shut if off to do something and it dieseled really bad. i tapped the throttle and it detonated and what appeared to be smoke poofed out of the bottom of the carb and valve covers. (i was in the car, i couldnt see too much) please tell me it could've been something else. I cant see water in the oil on the dipstick, but then again its only been run for 5 min. since thats happened. didnt see any blue smoke either. just the typical poof due to valve seals.
Old Oct 1, 2006 | 01:24 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I don't think you blew a head gasket doing that.
I'd start it back up and let it idle for a while. Set timing, go from there. Check your oil after it's running for a while, I think you're fine.
Old Oct 1, 2006 | 02:24 AM
Car: 89 GTA
Engine: 5.7L
sonix, youre always replying to my threads man. we shouldve gone for a cruise while i lived in calgary a few months ago.
i have tomorrow off so ill let you know how it goes, any carb/vacuum questions ill put on that other post with the pics.
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
NWAsonoma
Aug 18, 2015 05:45 PM
