Vortec heads better?
Old Oct 8, 2006 | 07:39 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Right now I have some sort of 305 heads on my 350.Would vortecs be better?
Old Oct 8, 2006 | 07:45 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
probably, need more info about your setup.
Old Oct 8, 2006 | 07:50 PM
85T/A350's Avatar
Engine: 350 Vortec
350 bored .40 over,600cfm edelbrock carb,edelbrock proformer intake,hooker shorty headers,non stock cam but not much bigger than stock
Old Oct 8, 2006 | 08:12 PM
85T/A350's Avatar
Engine: 350 Vortec
Can any one help?
Old Oct 8, 2006 | 08:21 PM
327???'s Avatar
if the 305 heads have not been ported then the vortecs are better, if they are ported then the vortecs MIGHT be better, it depends on how well they were done. you will need a new manifold with the vortecs.
Old Oct 8, 2006 | 08:48 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
I would vote for the vortecs. I picked up a set plus an edelbrock manifold to match for $300, with less than 100 miles on them. They are cheap, but its probably the best bang for your buck you can get. Check out some of Chevy Hi-Performance articles, they have done a few buildups with the Vortecs and have achieved some pretty decent numbers. Do you have a casting number off the 305 heads, or know what they came off of originally? Also what size cam are you running? If you know what your cam specs are, you can really narrow down your head selection and what your motor's wanting.
Old Oct 8, 2006 | 10:56 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Transmission: TH350 3000stall
i got great results with 906 vortec heads on a 355ci 13.1@104 no stall 3.42 gear
Old Oct 8, 2006 | 11:10 PM
spills's Avatar
Car: 89 RS
All I did on mine was port and polish out the exhaust a little (future nitrous plans), and other than low lift capabilities (easily fixed at the machine shop), they some pretty damn good heads.
Old Oct 9, 2006 | 12:43 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Vortecs are better. Well worth the $$$, even with the requirement of a new vortec manifold. Nobody that has ever swapped to a set from a stock head is ever going to say they are dissapointed.
Your 305 heads have tons of power potential at much less cost *if you're wiling to put the time and effort into them*.
They will need full porting and larger valves. You'll need to do much more than play around with a die grinder a bit.
I'm on my third set of vortecs and ported about 10 sets of 305 heads (416 casting). have flow tested both and had both on the same short block 350. About 1/2 the overall cost, easy 12sec street power.
Currently working on a set of Dart Iron Eagle 180's.
I'm haveing to do all the porting work to these heads to get them ready, that I do to the 305 heads.
Which 305 castings do you have?
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
