car wont run right
Old Oct 12, 2006 | 09:15 PM
91camarorallysp's Avatar
Car: 91 camaro rs
Transmission: auto
car wont run right
when i crank the car up it will run about thirty seconds then die. if you trie to hit the throttle it acts like its boggin down. when it gets around 180 degrees it will idle until you put it in gear and it bogs down again and you have to keep hitting the throttle before it will ever move.if anyone has a clue what this could be please let me know thanks
Old Oct 13, 2006 | 12:28 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Possibly a large vacuum leak What's the manifold vac reading? How's the fuel press? Any codes?
Old Oct 13, 2006 | 05:08 AM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Start with the basics. Check for vaccum leaks. Check fuel pressure to see if fuel pump and filter are operating properly. How long since you did a tuneup -cap, rotor, plugs , wires etc..etc..
Old Oct 13, 2006 | 08:11 PM
Car: 91 camaro rs
Transmission: auto
some people told me it could be the idle sensor could that be a reason
it aint got a vaccum leak and aint got the tool to check for any codes
Last edited by 91camarorallysp; Oct 13, 2006 at 08:13 PM. Reason: Automerged Doublepost
Old Oct 13, 2006 | 08:32 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
no tool required to check codes.
Just a paperclip. Do a search, its also in the tech section.
Old Oct 13, 2006 | 09:54 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
an injector may be starting to ground itself out and grounding out the circuit
while it is running take off one of the injector terminals if it stays running after the 30 seconds there is the problem
reading the ohms on injectors does not alway solve the problem
this is TPI we are dealing with right
I think sometimes I am wasting my time trying to help with board members cars and all of a sudden I realize that there is not enough info
please if you want us more experienced 3rd genners to help we will give you some of our time but you have to spend a little more time layin down the info we need
Help me Help you, show me the money and all that shizzel
Oh by the way welcome aboard
just bussin *****
Old Oct 16, 2006 | 09:08 PM
Car: 91 camaro rs
Transmission: auto
no its a throttle body sorry thought i had it in there
i bought the car a couple of weeks ago and it was in grass 6ft tall and had been there bought a year but i drove it home. it bogged a little then but gradually has got worse
Last edited by 91camarorallysp; Oct 16, 2006 at 09:11 PM. Reason: Automerged Doublepost
Old Oct 16, 2006 | 09:16 PM
Car: 91 camaro rs
Transmission: auto
i am goin to replace the idle sensor some time this week when i get a chance.maybe that is it if not i'll try somethin else
Old Oct 17, 2006 | 02:11 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
what about what the other suggested? Check the codes .... check for a vaccum leak . Do thats stuff too . Don't just throw parts at it.
Old Oct 18, 2006 | 04:04 PM
Car: 91 camaro rs
Transmission: auto
i brought home a scan tool today i'm goin to check this evenin and see what it pulls up
Old Oct 22, 2006 | 05:18 PM
Car: 91 camaro rs
Transmission: auto
i got that idle valve put on it helped, also put a new gasket on the throttle body.old one whas cracked. it will idle fine now once you get it warmed up but when i put it in reverse it bogs back down. think theres a leak around the intake goin to try to reseal it this week, thanks for the feedback yall
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
