gas in the oil?
Old Oct 13, 2006 | 09:47 PM
RandyZ's Avatar
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
gas in the oil?
is this possible and how do i fix it? i smell carbon too.
Old Oct 13, 2006 | 10:37 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
your running rich, or cranking and not getting her to start. Change the oil.
Old Oct 14, 2006 | 01:31 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
If you flood the engine badly this can wash the rings down and cause it to let gas by the rings and into the crankcase. Definitly want to change your oil pronto!
Old Oct 14, 2006 | 12:41 PM
RandyZ's Avatar
Well runing rich would that be the carbs falt ?how do i fix it? ilol change oil to night i have the carb ajusted to the highest vacuum.thats the right way right ,
Old Oct 14, 2006 | 01:33 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
If your oil had gas in it, change your oil. Gasoline does not lubricate
Old Oct 14, 2006 | 03:49 PM
RandyZ's Avatar
i don't understand
So if i chande the oil that will get rid of the gas and oil prob.Or is that going to come back.Is this a carb prob.or timing.
Old Oct 14, 2006 | 04:51 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
had the same problem not too long ago..its the fuel pump.. oh dont walk away when you drain the oil with all that gas in it.. i did.. emptied half onto my street :P
Old Oct 14, 2006 | 06:20 PM
izcain's Avatar
Engine: 584
I just tore a friends motor down since he was running it to rich and got a lil gas mixed with oil and it distroyed his rod bearings.... Bad news! Have you flooded it a lot? What do the plugs look like?
Old Oct 14, 2006 | 09:56 PM
RandyZ's Avatar
fixing it
Im changing my oil tonight will that fix it or is it too late? Motor is runing great so for ???? great oil psi . So someone please answer me why is it runing rich ive ajusted it so much where can i start.?
Firebird1984's Avatar
Car: 1984 Firebird S/E
Engine: 350 V8, 4 barrel carb
Transmission: 700 R4 automatic overdrive
I had this happen and as mentioned earlier, the fuel pump diaphram leaked and dumped gas into the oil pan. You might want to check that out. I had one case of this and it actually filled the crankcase to over full and hydrolocked the car. It would not crank as the pan was absolutely filled with oil to the point that the starter would not turn the engine over. I've never seen one this bad before this, but it happened to me!
Good luck!
Brad
Old Oct 14, 2006 | 09:59 PM
izcain's Avatar
Engine: 584
What kind of induction do you have?
Old Oct 14, 2006 | 10:07 PM
RandyZ's Avatar
holly 4b 600cfm mec sec dubble pumper ,torker2 intake that car screws with this set up and no prob going in any gear but pings when im at the bottom of my tank a little and the car idles funny
Old Oct 14, 2006 | 10:14 PM
izcain's Avatar
Engine: 584
Well do the basics first.... Check your float level since if you have it to high it will leak into the intake, Also check timing as your pinging thing concerns me. Are you running a mechanical pump or an electric pump? Regulated or non
Old Oct 14, 2006 | 10:32 PM
RandyZ's Avatar
running a holly blue ele fuel pump and holly reg at 7 psi
Old Oct 14, 2006 | 11:13 PM
izcain's Avatar
Engine: 584
You have a fuel gauge on there then? I would do those checks and then see what you came up with....
Old Oct 15, 2006 | 01:18 AM
Burntz's Avatar
Car: 1986 Trans Am
Engine: Mild 10:1 355.
Axle/Gears: 9 bolt
from what iv heard, if its a stick and you kill it, it can shove gas down in thier too, i may not be making sense, but in my moms 02 civic, the oil light came on, b/c the oil was 2 thin, and it happened after i tried to teach my g/f to drive it and she killed it 19893458 times, and someone told me it backfired gas into the oil.
Old Oct 15, 2006 | 07:17 PM
RandyZ's Avatar
umm
Well changed the oil and i will have the results tommoro .Hopfully everything goes well.I never heard any sounds out of the engine .Im going to check the float bowls tommoro
1992 Trans Am
May 10, 2023 07:19 PM
Derick15
Sep 17, 2016 05:28 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
