Speedometer Help
Old Oct 14, 2006 | 04:58 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Speedometer Help
gf's '89 RS-
When we got the car the speedometer was making noise and was bouncy. We put a new speedometer cable in (not lubed) and it worked and had been pretty good other then still a little bouncy for months. Yesterday (first cold morning about 38*) it started making horrid squealing noises and started flying all over the place. I had a whole cluster from the JY that I had laying around if I ever needed to swap speedometers. So I took out the old speedometer and put the new one in with the old (correct) odometer. No difference, it was still making noise and bouncing. Took the whole Speedometer cable out and lubed it with "Dry Graphite" lubricant. Just got it in and tried driving it around the block and it's still doing the exact same thing. Now when driving with the cable disconnected, it doesnt make any noise. Also if I try to turn the inner metal cable with my hand with it attached to the tranny it doesn't turn. So whats up? Was the second new speedometer i got from the JY no good either or do you think it's something else?
I dont know what to do and my gf needs a speedometer...
Old Oct 14, 2006 | 05:08 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I gave up on speedo's in my car, I have no luck at all with them...
That's normal, you've disconnected it from the speedo head, and it's still connected to the tranny gear, so you shouldn't be able to turn it. Here's a better test, connect it back to the speedo head, disco' it from the tranny. Try and spin the center part with your hand, while lying under the car. Get the wife to watch the speedo, does it move? If not, disco' it from the speedo head, and try again, can you turn it? If not the cable is obviously toast.
If it did move the speedo a bit, try using your drill, chuck up the center, and spin it slowly (make sure you spin it in the "right" direction.). Spin it up to 100mph if you have to, you'll get the noise, and be able to pinpoint it easily in the quiet garage, rather than over motor noise.
Old Oct 14, 2006 | 05:25 PM
Stevo's Avatar
Ya i know that is normal i just figured someone would post and tell me to test that. Im going out to try what you just said so ill post back with my results.
Thank you.
Old Oct 14, 2006 | 05:41 PM
Stevo's Avatar
Ok, speedo is definently making noise? Just dinging back and forth. Are we using the right kind of lube? Im pretty confident that the cable is fine and thats its the speedometer itself.
Old Oct 14, 2006 | 07:48 PM
Sonix's Avatar
Car: 1982 Trans-Am
Well, two speedo's in a row are bad you think?
no, I wouldn't use dry graphite. I'd pour gear oil down the tube, from the speedo side, so it runs down the tube via gravity.
Old Oct 14, 2006 | 09:33 PM
Stevo's Avatar
well we had to switch the odometer roll over so i had to remove the needle. I wasnt sure if i was messing up anything behind there because the stuff is so sensitive and fragile.
Gear lube it is in the A.M then if not im hittin the yards.
Old Oct 14, 2006 | 09:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Ringing like a bell? I'd put my money on both speedo heads being bad.
Old Oct 15, 2006 | 06:52 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I flushed the cable housing the brake cleaner, I think, until the fluid was clear, then I ran the cable itself through a palmful of Sly-Glyde, a Napa lube for speedo cables (as well as other things), down into the housing. Had to twist the cable a bit to seat it into the tranny gear.
By the way, are new GM cables prelubed?
JamesC
Old Oct 21, 2006 | 04:18 PM
Stevo's Avatar
Ok I put in a new(used) speedometer from another camaro in the JY, it works. No ringing. I used 80w90 gear oil on the cable and now it only makes a buzzing type noise above 40 mph and bounces around the speed...
Cable is like 5 months old too so i dont know whats up. Anymore ideas guys?
Old Oct 23, 2006 | 06:05 PM
Stevo's Avatar
anybody?
Old Dec 4, 2006 | 12:38 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
JamesC, so its possible to remove the spiral inner cable? My speedo cable just broke on me, and it seems easier to replace that inner cable rather than the whole thing.
Old Dec 4, 2006 | 01:18 PM
JamesC's Avatar
Yes, but make sure the new cable is the same length. IIRC, some auto parts stores sell cables that you can cut to length.
JamesC
Old Dec 4, 2006 | 11:36 PM
trumps2000's Avatar
Car: 1985 Z28
So I just removed the speedo cable and sure enough it broke in two near the trans. I think its was really dirty from sitting for years and was even up to its GFX in flood waters, but you can't keep a good 3rdGen down!
Since its broken in two I can't tell the proper length. James seems your car and mine are practically the same car right down the the color (cept mine's not an IROC and I bet your's is in much better condition), what was the length of your speedo cable?
Old Dec 5, 2006 | 05:25 AM
JamesC's Avatar
I was going to replace the cable itself, as you intend, but the auto parts version was clearly longer. Long story short, when the motor was out, I replaced the housing and cable with a new GM version. I'm not sure what the length was. Sorry.
JamesC
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
