ripped out my ac today, question
Old Oct 21, 2006 | 01:52 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
did you remove the black box on the firewall? or just cut the pipes.............and whats the black circular thing to the left of it towards passenger fender..................
Old Oct 22, 2006 | 09:08 AM
wasp's Avatar
bueller?
Old Oct 23, 2006 | 03:19 PM
wasp's Avatar
so noone else has ripped out ac huh? or you just think my post is too stupid to respond too?
Old Oct 23, 2006 | 04:04 PM
rtchaney's Avatar
Car: 89 RS
Transmission: Auto w/ evil shift kit; not my doin
Axle/Gears: It has a locker; not my doing
No big deal...
Yup, i took out my ac and amog/air system. All of it - including the black box on the fire wall. Becarefull not to disconect your blower motor or you will also have no heat or moving air for that mater. THe only other thing that you might need to know is that since i took mine out, the fan hasn't come on automatically. I ran a stand alone sensor to the fan so that it comes on at 165 deg.
Old Oct 23, 2006 | 04:23 PM
wasp's Avatar
i have no heat, ripped it out with radiator, my fan is always on with key, so that big black box can go? what about the black circle next to it? this isnt a daily driver so heat or ac is not needed..............too hot , or too cold its in the garage
Old Oct 23, 2006 | 04:29 PM
rtchaney's Avatar
Car: 89 RS
If it isn't a daily driver, and you don't need heat or air, pull it off. It's just the blower motor for the ac/heater. Also, you might as weel get rid of the heater hoses and heating element under the dash. It'll clean up the engine bay and help with weight. - after removing the blower motor, you will have a hole in your fire wall, you can buy block off plates or take the easy approach with a roll of duct tape.
Old Oct 23, 2006 | 04:59 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i have my heater blower off and the a/c gone how do i block off the heater hoselines since i dont need em or do i?
Old Oct 23, 2006 | 05:10 PM
rtchaney's Avatar
Car: 89 RS
The heater hoses, the two that runt into your fire wall and to the back of the intake manifold, can be removed and the caped of with some AN fittings on the manifold and the thermostat neck. Or, since you have an automatic fan, get a shiny new neck with out the ugly sensor on it to help pretty up the engine a little. If you get the new neck, you only need to block off the manifold - sorry i don't remember the size of the plug needed off hand. as for the heater core, leave it or pull your dash apart and get rid of it and all of the air plumbing to your vents if you want. My friend did this and the removed the AC/heater controller from his console and actually cut offthe excess plastic and removed the lower part that runs between the seats. That was about 30 lbs of plastic gone. He got a new shift boot and it looks very clean, short of the fade lines in the carpet.
Old Oct 23, 2006 | 05:16 PM
Engine: 355
ok i have one that goes in frontof the manifold and one to watr pump.. i dont have an electric fan.... do i just block the manifold one off and how do i do the water pump hose?
Old Oct 23, 2006 | 07:30 PM
wasp's Avatar
the blower motor is the circular thing or is it in the box? also, where do you get block off plates? or did you make them yourself
Old Oct 23, 2006 | 07:48 PM
Engine: 355
its the circular thing.... i made my own plates outta thin sheet metal and painted to match firewall... u remove ur heater hoses? i need to know how to block of water pump hose
Old Oct 23, 2006 | 09:20 PM
wasp's Avatar
yes i did, but i did it when i installed a griffin aluminum radiator, i cant recall but i think this eliminates the hose your talking about.............
Old Oct 23, 2006 | 09:34 PM
rtchaney's Avatar
Car: 89 RS
The easiest way is to get an allen key plug that will bolt right in to place. But, if you can spare a little cash, save some weight with a new aluminm water pump. It won't have the provision that you need to block.
Old Oct 23, 2006 | 09:45 PM
Engine: 355
would i be able to route the hose from the water pump to the manifold? would it cause to much pressure, cooling issues or anything of that sort?
Old Oct 24, 2006 | 12:54 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
I would take the easy approach, either block off at the pump, or better yet, look at where the other line comes from the heater core, it should go back into the radiator; reroute your hose from the pump back into the radiator.
Old Oct 24, 2006 | 04:54 PM
Engine: 355
itdont go into radiator anybody know the sizes for the manifold and water pump to block off?
Old Oct 24, 2006 | 05:55 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Is anyone else reading this and shaking their head? Why are you ripping and tearing things out of this car? What are you accomplishing here besides killing any resale value the car might have had? Are you trying to shave pounds to take it drag racing? There are better ways...
That has to be the worst way to shave a half of a pound off I've ever heard of.. duct tape?
No wonder everyone looks down on us third genners
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
spaigo
Aug 21, 2015 07:46 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
