Casting Confusion
Old Nov 1, 2006 | 05:32 PM
zrated57's Avatar
Casting Confusion
I have a Goodwrench crate engine and the casting number is 10066038. The confusion I'm having is that on some websites it says the engine was made in 1992 and on other sites is says it's made in 1994. How do I tell which year it was really made in?
Since it was built in either '92 or '94, but has a 2-piece rear main seal, I should use pre-86 parts, correct?
If GM stopped making 2-piece blocks in the mid 80's, then why did they make a 2-piece in the 90's? I got this engine block from a friend because it had spun a bearing and I wanted to use it for my 383. I hope this block is a canidate.
Old Nov 1, 2006 | 06:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check the date code cast into the block if you want to know what year it was made, but it really doesn't matter.
GM didn't stop making 2 piece RMS blocks in 1986, they only stopped using them in new cars. That block was cast by GM as an over-the-counter replacement block for 2 piece RMS engines.
Old Nov 1, 2006 | 06:21 PM
zrated57's Avatar
Where is the date code usually stamped?
Old Nov 1, 2006 | 07:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
MorTec, Chevy V-8 Engine Block and Head Casting Number Locations
Old Nov 1, 2006 | 07:49 PM
zrated57's Avatar
Do you think this would make a good high performance block? It's been to the machine shop already. I had it baked, magnafluxed checked for cracks, bored, new cam bearing and new freeze plugs. It was also stoker clearanced.
Old Nov 1, 2006 | 09:30 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by zrated57
... I got this engine block from a friend because it had spun a bearing and I wanted to use it for my 383. I hope this block is a canidate.
I sure hope you meant it had spun a rod bearing... If it didn't spin a main, it should be fine.
Old Nov 2, 2006 | 02:01 AM
zrated57's Avatar
Yeah, it was a rod bearing. And it appeared that the crankshaft had been shimmed, too. It's strange because the disassemble I did was the first it had been disassembled since the engine was built by GM. Which makes me wonder why it had been shimmed from the factory. It was brand new when my buddy bought it and I got the engine with 40,000 miles and bearing failure. hmm
Old Nov 2, 2006 | 10:37 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
The year doesn't matter. The RMS will determine your crank (obviously) and then you have to decide on the build. Anything can be built into a performance motor, it all depends on how much money and time you are willing to throw at it.
That said, the bigger question would be if it was cast with the roller bosses or not. I'm guessing not, eh?
Old Nov 2, 2006 | 11:40 AM
zrated57's Avatar
You guessed right, it's not, but I am going to retro-fit it. That is pretty darn expensive as I've found out from doing a bit of research. I didn't know that some of the blocks were made in Mexico, but I learn something new everyday.
Galaxie500XL
Feb 1, 2020 04:53 AM
skinny z
Oct 5, 2015 06:23 PM
mfp189
Sep 27, 2015 09:25 AM
6998poncho
Sep 25, 2015 02:56 PM
bubbaz28
Sep 18, 2015 02:09 PM
