please confirm my engine...
Car: 1990 Corvette
Engine: 415
Transmission: six speed
Axle/Gears: Dana44 3.73
Hi all
i built this engine, it runs fine, pulls nice, just wanted to know what you think about...
396ci
AFR 210cc heads
single plane EFI intake
234/238 288/292 112LSA .565cam
10.6:1 compression..
would you say this is a nice combo, or do you think, the heads are too big?
regards
396ci
AFR 210cc heads
regards
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
It's confirmed... it's an engine.
On the edge of a decision with those heads. I'd probably have gone with smaller heads or a bigger cam. :shrug:
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
What rod/piston combo was used?
I shopped around for pistons for one of those once and I found that there aren't many matched rod piston sets available to fit the SBC deck height. Or at least not ones that would make it easy to tailor my CR to work with the heads I wanted to use.
Car: 1990 Corvette
Engine: 415
Hi
i used a 3.875" stroke crank, 6" rods and JE Pistons with 1.062" comp.height
i ordered the complete rotating assy through Eagle...
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
holy crap you need bigger runners for that poor thing. you could go to a ~230cc int runner and still have LOTS of tq down low. what header primaries are u using?
Car: '85 IROC
Engine: LB9
tyeo098
Nov 30, 2015 06:27 PM
buckeyecelt
Sep 24, 2015 05:50 AM
89 formula TPI
Sep 7, 2015 11:06 AM
